[petsc-dev] usage of Malloc2 at VecScatterCopy_MPI_ToAll
Lisandro Dalcin dalcinl at gmail.com
Fri Jul 9 20:14:57 CDT 2010
On 9 July 2010 22:07, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Hmm, looks like we could use a Malloc3() there :-) Even better.
Is this safe regarding memory alignment?
>   Barry
> On Jul 9, 2010, at 8:00 PM, Lisandro Dalcin wrote:
>> On 9 July 2010 21:26, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>  I consider this bogus warnings.
>> I agree on that. My point is the actual usage of Malloc2.
>>  ierr                =
>> PetscMalloc2(1,VecScatter_MPI_ToAll,&sto,size,PetscMPIInt,&sto->count);CHKERRQ(ierr);
>>  ierr                =
>> PetscMalloc(size*sizeof(PetscMPIInt),&sto->displx);CHKERRQ(ierr);
>> What's the point of allocating 1 struct + size ints, and next size
>> more ints? I would use Malloc for the struct, and then Malloc2 for the
>> two arrays.
>>>   Barry
>>> On Jul 9, 2010, at 7:22 PM, Lisandro Dalcin wrote:
>>>> While building with nvcc, I looked at this warning:
>>>> libfast in: /usr/local/petsc/dev/src/vec/vec/utils
>>>> vscat.c(322): warning: variable "sto" is used before its value is set
>>>> Do we really need to use Malloc2 in such line? Perhaps we should
>>>> actually use Malloc2 for sto->count and sto->displx ?
>>>> Lisandro Dalcin
>>>> CIMEC (INTEC/CONICET-UNL)
>>>> Predio CONICET-Santa Fe
>>>> Colectora RN 168 Km 472, Paraje El Pozo
>>>> Tel: +54-342-4511594 (ext 1011)
>>>> Tel/Fax: +54-342-4511169
>> Lisandro Dalcin
Lisandro Dalcin
