[petsc-dev] usage of Malloc2 at VecScatterCopy_MPI_ToAll
    Lisandro Dalcin
    dalcinl at gmail.com
    Fri Jul  9 20:00:21 CDT 2010
On 9 July 2010 21:26, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  I consider this bogus warnings.
I agree on that. My point is the actual usage of Malloc2.
  ierr                =
PetscMalloc2(1,VecScatter_MPI_ToAll,&sto,size,PetscMPIInt,&sto->count);CHKERRQ(ierr);
  ierr                =
PetscMalloc(size*sizeof(PetscMPIInt),&sto->displx);CHKERRQ(ierr);
What's the point of allocating 1 struct + size ints, and next size
more ints? I would use Malloc for the struct, and then Malloc2 for the
two arrays.
>   Barry
> On Jul 9, 2010, at 7:22 PM, Lisandro Dalcin wrote:
>> While building with nvcc, I looked at this warning:
>> libfast in: /usr/local/petsc/dev/src/vec/vec/utils
>> vscat.c(322): warning: variable "sto" is used before its value is set
>> Do we really need to use Malloc2 in such line? Perhaps we should
>> actually use Malloc2 for sto->count and sto->displx ?
>> Lisandro Dalcin
>> CIMEC (INTEC/CONICET-UNL)
>> Predio CONICET-Santa Fe
>> Colectora RN 168 Km 472, Paraje El Pozo
>> Tel: +54-342-4511594 (ext 1011)
>> Tel/Fax: +54-342-4511169
Lisandro Dalcin
