[petsc-dev] Simplifying PETSc Debugging in Totalview
Barry Smith
bsmith at mcs.anl.gov
Thu Jul 1 16:56:33 CDT 2010
On Jul 1, 2010, at 4:42 PM, Lisandro Dalcin wrote:
> On 29 June 2010 16:44, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> PETSc users,
>> Jeff Keasler has pointed out that TotalView 8.8 and later support a new feature where libraries can provide code that displays the contents of an object in any useful format (allowing for example, PETSc to provide code to nicely display entries of a sparse matrix in the debugger). I have tried this out by including in petsc-dev a very simple viewer for Vec and Mat; these will just work if you use TotalView 8.8 or higher with PETSc-dev.
>> If any users really love using Totalview with PETSc and would like to see this extended (or extend it themselves :-) the example source code is in src/vec/vec/interface/vector.c called TV_display_type() and please get in touch with us.
> vector.c:713: warning: ‘TV_display_type’ defined but not used
> matrix.c:735: warning: ‘TV_display_type’ defined but not used
Don't have a good cure for this.
Barry
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
