[petsc-dev] SuperLU link error on BGP FEN
Xiaoye S. Li
xsli at lbl.gov
Fri Dec 31 22:37:23 CST 2010
I updated the tarball with the patch. I also did cleaning of the other
routines, to be sure the routines return proper values.
Sherry
On Thu, Dec 30, 2010 at 6:01 PM, Jed Brown <jed at 59a2.org> wrote:
> On Thu, Dec 23, 2010 at 09:18, Satish Balay <balay at mcs.anl.gov> wrote:
>> petsc configure will now download superlu/superlu_dist directly from
>> this location as we won't have any more local patches..
> We need one more patch (attached) to compile with Clang. This only fixes
> the fatal errors, none of the calls to these functions check the return
> value so maybe they should just return void.
> Additionally, there are lots of functions returning non-void but lacking a
> return statement. This is not valid C, but Clang (and other compilers,
> evidently) happen to only issue warnings for these violations.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101231/29fbea9e/attachment.html>
