[petsc-dev] What do people want to have working before a petsc-3.2 release?
Mark F. Adams
adams at pppl.gov
Wed Dec 22 21:58:18 CST 2010
I've been concerned for a while that, as Barry says, ParMetis seems
orphaned. I've had problems with scaling ParMetis up on BG for a
while. I believe they allocate a PxP (integer) matrix which kills my
code (my code is flat MPI but I make sub communicators so that each
ParMetis MPI process has the whole node to itself). Can anyone scale
Parmetis up on BG-P?
Anyway this has been on my wish list for a while so I thought I'd use
this opportunity to see if anyone has ideas for a solution.
On Dec 22, 2010, at 7:50 PM, Matthew Knepley wrote:
> On Wed, Dec 22, 2010 at 3:02 PM, Lisandro Dalcin <dalcinl at gmail.com>
> wrote:
> On 22 December 2010 19:57, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Dec 22, 2010, at 4:51 PM, Lisandro Dalcin wrote:
> >> On 21 December 2010 20:50, Sean Farley <sean at mcs.anl.gov> wrote:
> >>>>> fixing/understanding 64-bit checks,
> >>>> I think these checks are ok, please report problems.
> >>> Would it be possible to get ParMetis working with 64bit indices?
> >>> Sean
> >> This is from parmetis.h
> >> /* Indexes are as long as integers for now */
> >> #ifdef IDXTYPE_INT
> >> typedef int idxtype;
> >> #else
> >> typedef short idxtype;
> >> #endif
> >> Have any of you seriously tryied parmetis in 64 bits?
> > Yes, when I noticed that block of code several years ago. Looks
> like it would be easy to switch to long int but sadly this include
> is misleading about the simplicity, turns out this typedef beasty is
> not used throughout the source code consistently.
> Damn,
> > I sent email about the 64 bit int at that time and got back the
> response "in a few months". Note that his non-MPI codes may fully
> support the 64 bit (I'm guessing that is where the $ is so is all he
> cares about). That was like two years ago. I consider Parmetis
> orphaned, not maintained, hence in the HPC world, dead.
> Add to that license issues. A fork in order to maintain and improve it
> is unlikely.
> If this is a big deal, I can mail George directly. He let me fool
> with the tarball and distribute it
> with PETSc last time I asked him.
> Matt
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101222/31b91df8/attachment.html>
