[petsc-dev] [petsc-maint #59097] TSTheta
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Dec 21 11:34:18 CST 2010
  Michael,
   We intentionally have kept Jed off the petsc-maint email list so he can get work done. This can be discussed in the petsc-dev at mcs.anl.gov list
   Barry
On Dec 21, 2010, at 4:26 PM, Michael E Henderson wrote:
> Hi,
> Who can I talk to about the implementation of the TSTheta Implicit time
> stepper?
> The implementation computes ts->vec_sol which solves the implicit system.
> But the monitor returns ts->vec_sol+dt*th->Xdot, which does not
> necessarily satisfy the equations. At least that's how I read the code. I
> think that the call to VecAXPY which changes ts->vec_sol needs to be moved
> to after the call to TSMonitor in src/ts/impls/implicit/theta/theta.c
> Purely a matter of what is passed to the monitor routine.
> Thanks,
> Mike Henderson
> Mathematical Sciences, TJ Watson Research Center
> mhender at watson.ibm.com
> http://www.research.ibm.com/people/h/henderson/
> http://multifario.sourceforge.net/
> Hi,
> Who can I talk to about the implementation of the TSTheta Implicit time stepper?
> The implementation computes ts->vec_sol which solves the implicit system. But the monitor returns ts->vec_sol+dt*th->Xdot, which does not necessarily satisfy the equations. At least that's how I read the code. I think that the call to VecAXPY which changes ts->vec_sol needs to be moved to after the call to TSMonitor in src/ts/impls/implicit/theta/theta.c Purely a matter of what is passed to the monitor routine.
> Thanks,
> Mike Henderson
