[petsc-dev] path used for make run in Emacs not set
    Jed Brown
    jed at 59A2.org
    Tue Dec  7 19:43:44 CST 2010
On Wed, Dec 8, 2010 at 02:38, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Thanks, but that is painful because my path changes and I'd prefer to have
> it just get if from my .bashrc
http://procrastiblog.com/2007/07/09/changing-your-path-in-emacs-compilation-mode/
I tend to just put "special" stuff in the command line (otherwise I would
forget) and leave the rest static.  In this case, why is "nvcc" being
invoked without its full path?  Isn't that a configure issue?
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101208/a1be57c8/attachment.html>
