[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
Dmitry Karpeev
karpeev at mcs.anl.gov
Tue Dec 7 15:40:37 CST 2010
And yet DMDA already defines this local fine-granularity "stencil" access.
Where would it go, if not in the DM? In my opinion this is part of the
function space definition:
it generalizes VecGetArray to something more geometric.
Not all DMs have to implement this.
On Tue, Dec 7, 2010 at 3:35 PM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Dec 7, 2010 at 22:06, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> But those that *want* to know, can obtain the underlying DM and start
>> doing cool stuff
>> to the Vec. In particular, DM is the natural place to inject geometric
>> information, generalizing DMDA to the unstructured
>> case. For example, a DM can allow to access the Vec data by "stencil",
>> which in the DMDA case is the usual thing,
>> and in the unstructured mesh case is, say, element restrictions. This
>> would encapsulate the "expanded space" idea
>> that Jed described a while ago in a tentative unstructured API. This
>> would require, however, some iterator model,
>> which is a kind of flexible local fine-granularity "on demand" scatter.
> This functionality is all in Level 3 of my earlier message, it's not a part
> of the DM API that Vec should be aware of.
> The only parts of the DM API that I think Vec should be aware of is
> PetscLayout, the "overlap" scatters, and DMVecView. The last one is purely
> cosmetic because VecGetDM, DMVecView is so common.
> Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101207/16ef8b4c/attachment.html>
