[petsc-dev] SuperLU link error on BGP FEN
Xiaoye S. Li
xsli at lbl.gov
Fri Dec 3 18:31:51 CST 2010
Sorry, but just got around to look at this.
In SuperLU_4.0, we introduced ILU preconditioner, which works better with
MC64 permutation (which is written in f77). But I forgot to include this
in slu_Cnames.h, to handle the name mangling issue.
In SuperLU_4.1, I converted MC64 from f77 to C using f2c. Therefore, there
is no such name mangling problem. The C version is now also used in
SuperLU_DIST_2.5.
In summary, SuperLU_4.1 and SuperLU_DIST_2.5 upward versions should not need
this name mangling for MC64.
Sherry
On Thu, Dec 2, 2010 at 1:40 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Looks like a bug in superlu. [this bug doesn't exist in superlu_dist].
> I suspect we've always used superlu with superlu_dist on bgp - so
> didn't see this before. [symbols from -lsuperlu_dist must have been
> picked up by the linker (before superlu symbols) - and these symbols
> resolved without errors]
> The following fixes the issue.
> login2.surveyor:SuperLU_4.0/SRC > diff -Nru slu_Cnames.h~ slu_Cnames.h
> --- slu_Cnames.h~ 2009-07-05 00:55:49.000000000 -0500
> +++ slu_Cnames.h 2010-12-02 15:19:30.005247114 -0600
> @@ -251,6 +251,9 @@
> #define izmax1_ IZMAX1
> #define zlacon_ ZLACON
> +#define mc64id_ MC64ID
> +#define mc64ad_ MC64AD
> /* Fortran interface */
> #define c_bridge_dgssv_ C_BRIDGE_DGSSV
> #define c_fortran_sgssv_ C_FORTRAN_SGSSV
> @@ -350,6 +353,9 @@
> #define izmax1_ izmax1
> #define zlacon_ zlacon
> +#define mc64id_ mc64id
> +#define mc64ad_ mc64ad
> #define c_bridge_dgssv_ c_bridge_dgssv
> #define c_fortran_sgssv_ c_fortran_sgssv
> I've respun the superlu download tarball with this fix..
> Note: Looks like Superlu_4.1 tarball has this bug..
> Satish
> On Thu, 2 Dec 2010, Satish Balay wrote:
> > I'll attempt a build and see how it goes..
> > satish
> > On Thu, 2 Dec 2010, Matthew Knepley wrote:
> > > We always always always always need configure.log.
> > > Matt
> > > On Thu, Dec 2, 2010 at 8:41 AM, John R. Cary <cary at txcorp.com> wrote:
> > > > I am trying to link facets on a FEN of surveyor.alcf.anl.gov. It
> ends
> > > > with the error,
> /gpfs/home/projects/facets/surveyor/contrib-xlc-9.0/petsc-3.1-p4-ser/lib/libsuperlu_4.0.a(dldperm.o):
> > > > In function `dldperm':
> /gpfs/home/cary/facetspkgs/builds/petsc-3.1-p4/ser/externalpackages/SuperLU_4.0/SRC/dldperm.c:127:
> > > > undefined reference to `mc64id_'
> /gpfs/home/cary/facetspkgs/builds/petsc-3.1-p4/ser/externalpackages/SuperLU_4.0/SRC/dldperm.c:134:
> > > > undefined reference to `mc64ad_'
> > > > which indicates that the SuperLU compiled with PETSc did
> > > > not get the fortran underscoring flag correct (which should
> > > > be no underscore with xlf). nm shows
> > > > login1.surveyor$ nm
> > > > | grep mc64
> > > > U mc64ad_
> > > > U mc64id_
> > > > mc64ad.o:
> > > > 0000000000000018 D mc64ad
> > > > 0000000000000030 D mc64bd
> > > > 0000000000000048 D mc64dd
> > > > 0000000000000060 D mc64ed
> > > > 0000000000000078 D mc64fd
> > > > 0000000000000000 D mc64id
> > > > 00000000000000c0 D mc64qd
> > > > 0000000000000090 D mc64rd
> > > > 00000000000000a8 D mc64sd
> > > > 00000000000000d8 D mc64ud
> > > > 00000000000000f0 D mc64wd
> > > > U mc64ad_
> > > > U mc64id_
> > > > that the underscored symbol is being called, but the
> > > > underscore-free symbol is what was defined.
> > > > My PETSc configure line was
> > > > #!/bin/sh
> /gpfs/home/cary/facetspkgs/builds-surveyor-xlc/facetspkgs/petsc-3.1-p4/ser/configure
> --prefix=/gpfs/home/projects/facets/surveyor/contrib-xlc-9.0/petsc-3.1-p4-ser
> > > > --with-mpi=0 \
> > > > --with-debugging=0 \
> > > > --with-x=0 \
> > > > --with-cc='xlc_r' \
> > > > --with-cxx='xlC_r' \
> > > > --with-fc='xlf_r' \
> > > > --COPTFLAGS='-O2 -g' \
> > > > --download-superlu \
> --with-lapack-lib=/home/projects/facets/intrepid/contrib/lapack-ser/lib/liblapack.a
> --with-blas-lib=/home/projects/facets/intrepid/contrib/lapack-ser/lib/libblas.a
> PETSC_DIR=/gpfs/home/cary/facetspkgs/builds-surveyor-xlc/facetspkgs/petsc-3.1-p4/ser
> > > > PETSC_ARCH=facets-ser \
> > > > --CFLAGS='-q64 -qlanglvl=redefmac' \
> > > > --CXXFLAGS='-q64 -qlanglvl=redefmac' \
> > > > --FFLAGS='-q64 -qextname=flush' \
> > > > --with-shared=1
> > > > so I think that PETSc had enough info to figure out the underscoring.
> > > > Perhaps this is a bug.
> > > > But regardless, is there a workaround?
> > > > Thx....John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101203/b4e206fa/attachment.html>
