[petsc-dev] Shifting in ICC, changes?
Hong Zhang
hzhang at mcs.anl.gov
Fri Dec 3 11:00:42 CST 2010
Jed,
We replaced old numerical factorization and MatSolve with faster data structure,
then cleaned up MatPivotCheck() (still using previous algorithm).
Changes, such as
changeset: 15909:fbc1ba94d8d9
user: hong at hong-zhangs-macbook-air.local
date: Wed May 12 22:17:30 2010 -0500
files: src/mat/impls/aij/seq/aijfact.c
description:
replace macros with inline function MatPivotCheck() for inplace lu (aij format)
could accelerate performance.
Hong
On Fri, Dec 3, 2010 at 4:55 AM, Jed Brown <jed at 59a2.org> wrote:
> What exactly changed between Feb 1 and the petsc-3.1 release with respect to
> shifting (including for (S)BAIJ). In Feb, I saw negative pivots and blamed
> certain performance characteristics on it. Now I don't see them, despite
> the fact that SBAIJ does not implement the same shifts that AIJ does. The
> performance now (or with 3.1) is significantly better, but I would like to
> be able to explain what's going on. Running with -pc_factor_shift_type none
> is still working much better than Feb 1 -dev and I would like to know why.
> Jed
