[petsc-dev] SuperLU link error on BGP FEN
Jed Brown
jed at 59A2.org
Thu Dec 2 16:30:03 CST 2010
On Thu, Dec 2, 2010 at 23:19, Matthew Knepley <knepley at gmail.com> wrote:
> How exactly does that happen? I have just checked that I ran multiple
> configures and did not clobber those logs.
When a new configure process starts, it truncates the file. You only
relocate it later. It's a race condition, so may not happen every time, or
you might not have correct contents in each of your files.
> I do not think this works on NTFS.
NTFS is lame and does not have a way to atomic rename when the destination
file exists. But it does have both hardlinks and symlinks. In the proposed
model $PETSC_DIR/configure.log is only a convenience for the user, it is not
being read or written concurrently, so the fact that redirecting the symlink
cannot be done atomically should not be a problem (racing a human is safer
than racing another process).
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101202/56509e4a/attachment.html>
