[petsc-dev] SuperLU link error on BGP FEN
Jed Brown
jed at 59A2.org
Thu Dec 2 16:14:06 CST 2010
On Thu, Dec 2, 2010 at 23:06, Matthew Knepley <knepley at gmail.com> wrote:
> The problem with this is that we automatically determine PETSC_ARCH in the
> course of configure, well
> after we start logging. We do symlink it at the end.
Yes, but the file gets truncated by the configure process that fires up
afterward. You could
create it as a temporary file in $PETSC_DIR (mktemp)
symlink configure.log to this temp file
wait until you know PETSC_ARCH
hardlink $PETSC_ARCH/conf/configure.log to the temp file
redirect the symlink to $PETSC_ARCH/conf/configure.log
remove the temp file
This process should be atomic and always have a usable state even with
concurrent configures and unpredictable failures (though I suppose the help
message should ask the user to send the real file instead of the symlink
which could point elsewhere).
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101202/16603cdf/attachment.html>
