[petsc-dev] Fwd: [petsc-maint #57017] Hypre
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Dec  2 08:00:02 CST 2010
Begin forwarded message:
> From: Laurent Michel <laurent.michel at epfl.ch>
> Date: December 2, 2010 5:25:38 AM CST
> To: petsc-maint at mcs.anl.gov
> Subject: Re: [petsc-maint #57017] Hypre
> Reply-To: petsc-maint at mcs.anl.gov, Laurent Michel <laurent.michel at epfl.ch>
> Ok. That sounds much easier. So, during the building of the linear
> system, I do something like (when computing the CSR format)
>    PetscInt start, end; MatGetOwnershipRange(A, &start, &end);
>    vector<int> idv, idp; // velocity and pressure indices
>    int index = 0, row = 0;
>    for (int i = 0; i < nbNodeP1; i++) { // Loop over the nodes of the
> mesh (P1 nodes)
>        for (int ndof = 0; ndof < 4; ndof++) { // Loop over the degrees
> of freedom of each node; 3 for v, 1 for p
>            if(!nodes[i].is_fixed(ndof)){ // if the node is free, then
> put it in the linear system
>                if(start <= row && row < end){ // each process does its
> own part of the job
>                    [stuff for CSR format]
>                    if(0 <= ndof && ndof < 3) // velocity
>                        idv.push_back(row);
>                    else // pressure
>                        idp.push_back(row);
>                row++;
>    // conversion to arrays
>    int *idp_ptr = new int [idp.size()], *idv_ptr = new int
> [idv.size()]; // fieldsplit indices
>    memcpy(idp_ptr, &idp[0], sizeof(int)*idp.size());
>    memcpy(idv_ptr, &idv[0], sizeof(int)*idv.size());
>    // conversion to IS
>    IS isv, isp;
>    ISCreateGeneral(PETSC_COMM_WORLD, idp.size(), idp_ptr, &isp);
>    ISCreateGeneral(PETSC_COMM_WORLD, idv.size(), idv_ptr, &isv);
> Then, when I create the preconditioner, I say
> PCSetType(pc, PCFIELDSPLIT);
> PCFieldSplitSetIS(pc, isv);
> PCFieldSplitSetIS(pc, isp);
> I guess the order matters here. Then, when I call the code, I call it
> among other things with
> -pc_fieldsplit_type multiplicative -fieldsplit_0_pc_type ml
> -fieldsplit_1_pc_type jacobi
> Ok. Now the thing is, I haven't compiled the ml library, and it seems
> like the petsc servers are down (I can't download anything). Anyway, I
> wanted to try this with something else. Hence, I tried in SEQUENTIAL
> -pc_fieldsplit_type multiplicative -fieldsplit_0_pc_type ilu
> -fieldsplit_0_pc_factor_levels 2 -fieldsplit_1_pc_type jacobi
> and this works fine; in parallel, with
> -pc_fieldsplit_type multiplicative -fieldsplit_0_pc_type asm
> I get something working. I think I've been able to code this. I'll let
> you know if I encounter some problems with the ml preconditioner (I have
> no idea what it is, so I may have problems).
> Regarding all this, I have to mention that until now I've had to reorder
> my matrix elements with
> -pc_factor_mat_ordering_type rcm
> because it seems like the nodes of my mesh are not numbered
> appropriately. How should I proceed for parallel computations? In
> sequential, I gain about a factor 8 in CPU time doing this.
> Thanks,
> L.
> Matthew Knepley wrote:
>> On Wed, Dec 1, 2010 at 8:38 AM, Laurent Michel <laurent.michel at epfl.ch
>> <mailto:laurent.michel at epfl.ch>> wrote:
>>    Well I'm actually struggling finding a good, scalable
>>    preconditioner for
>>    my problem. This is one of the problems I have to solve these days.
>>    I have spoken to a few people here who are kind of experts in the
>>    field
>>    of hpc, and I have always got the same answer: the Stokes problem will
>>    not scale well. I found some people working on more or less the same
>>    problem as I do who actually have a scalable code (sisiphus for
>>    instance; I am solving a glacier problem).
>>    I wanted to use the fieldsplit preconditioner, I already roughly
>>    discussed this with Mr. Knepley, but I'm not quite sure yet how to do
>>    this; I mean, I have an unstructured mesh, and I need to define
>>    some DAs
>>    to make the fieldsplit preconditioner work. It seems complicated.
>> I did not do a good enough job explaining. FieldSplit should not be
>> hard for your
>> problem. You just need to create lists of the unknowns in each field.
>> Each list
>> will be an IS object. Then you call
>>  http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
>> once for each field. Then you can independently handle the velocity and
>> pressure preconditioners, and it should produce a scalable solver. I would
>> try -pc_fieldsplit_type multiplicative -fieldsplit_0_pc_type ml
>>   Matt
>>    In parallel to this, I have seen that decoupling the velocity from the
>>    pressure field (with like an Uzawa method or something like that; I'm
>>    not an expert here) may be more scalable. I gather this is the same as
>>    your fieldsplit preconditioner. I'll have a more thorough look
>>    into this
>>    if so. There is to my knowledge (which is very small) no documentation
>>    related to the handling of unstructured problems with your fieldsplit
>>    preconditioner, which I think might be the best option for me. ASM
>>    doesn't work well (I have awful results on my cluster; see
>>    attachment).
>>    I'm solving Ax = b here, with A being the whole finite element matrix,
>>    containing the data related to all the fields (velocity and pressure).
>>    Any hint on what I could try? It's not central for my PhD thesis, but
>>    I'd enjoy some faster code!
>>    Regards,
>>    L.
>>    Barry Smith wrote:
>>> On Dec 1, 2010, at 2:44 AM, Laurent Michel wrote:
>>>> Hi,
>>>>   * OS Version: Linux iacspc3 2.6.31-22-generic #68-Ubuntu SMP
>>    Tue Oct
>>>>     26 16:37:17 UTC 2010 x86_64 GNU/Linux
>>>>   * PETSc Version: Fri Apr 30 20:23:44 CDT 2010
>>>>   * MPI implementation: openmpi
>>>>   * Compiler: g++
>>>>   * Probable PETSc component: PC
>>>> My question is about the use of preconditioner Hypre. I have a
>>    colleague
>>>> who uses hypre directly and solves more or less the same kind
>>    of problem
>>>> as I do. His code scales pretty well (3D Navier-Stokes) and I
>>    wanted to
>>>> try hypre in mine, in order to see what happens. Indeed, for my
>>    problem,
>>>> it's known that the algebraic Schwarz method will not scale
>>    that good
>>>> (this also what I have noticed during my numerical
>>    experiments). Anyway,
>>>> I've tried to run my code with the following additional options:
>>>> -pc_type hypre -pc_hypre_type euclid
>>>> and it takes forever to solve the linear system (I mean, to
>>    apply the
>>>> preconditioner and then actually solve the system).
>>>   Likely Euclid is a bad preconditioner for your problem. Run
>>    with -log_summary -ksp_converged_reason to completion and then
>>    look at the output to see where it is spending all the time. If
>>    the time is truely dominated by PCSetUp and or PCApply or requires
>>    many many iterations then Euclid is the problem. We've found the
>>    Euclid doesn't scale or perform particularlly well.
>>>   If your problem is a "Stokes" like problem that just throwing
>>    a generic preconditioner like Euclid at it without doing something
>>    special for the fact that it is "Stokes like" problem won't work
>>    well. Perhaps Jed has some suggestions.
>>>   Barry
>>>> I'm using the MPIAIJ matrix format, with
>>    MatMPIAIJSetPreallocationCSR.
>>>> Should I use another format? I've been struggling looking for
>>>> documentation about this. Where can I find any further information?
>>>> Regards,
>>>> L.
>>>> Laurent Michel
>>>> PhD candidate
>>>> EPFL SB IACS ASN
>>>> MA C2 644
>>>> +41 21 693 42 46
>>>> +41 77 433 38 94
>>    Laurent Michel
>>    PhD candidate
>>    EPFL SB IACS ASN
>>    MA C2 644
>>    +41 21 693 42 46
>>    +41 77 433 38 94
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
> Laurent Michel
> PhD candidate
> EPFL SB IACS ASN
> MA C2 644
> +41 21 693 42 46
> +41 77 433 38 94
