[petsc-dev] [GPU] Performance of ex19
Barry Smith
bsmith at mcs.anl.gov
Tue Aug 31 10:53:10 CDT 2010
Please run with the options ./ex19 -da_vec_type seqcuda -da_mat_type seqaijcuda -pc_type none -dmmg_nlevels 1 -da_grid_x 100 -da_grid_y 100 -log_summary -mat_no_inode -preload off -cuda_synchronize
On Aug 31, 2010, at 11:45 AM, Keita Teranishi wrote:
> Hi PETSc Developer team,
> I have just measured the performance of ex19 program running on Fermi GPU. I hope it will help you to develop GPU-enabled PETSc further.
> Thanks,
> Keita
> ./ex19 -pc_type jacobi -dmmg_nlevels 5 -da_vec_type cuda -da_mat_type aijcuda -log_summary -cuda_synchronize
> --- Event Stage 0: Main Stage
> PetscBarrier 2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> --- Event Stage 1: SetUp
> VecSet 8 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecCUDACopyFrom 8 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatMultTranspose 4 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 58 0 0 0 0
> MatAssemblyBegin 9 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatAssemblyEnd 9 1.0 3.9999e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 14 0 0 0 0 0
> MatFDColorCreate 5 1.0 1.2000e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 43 0 0 0 0 0
> --- Event Stage 2: Solve
> VecDot 2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecMDot 980 1.0 5.5599e-01 1.0 2.95e+08 1.0 0.0e+00 0.0e+00 0.0e+00 10 14 0 0 0 39 28 0 0 0 530
> VecNorm 1025 1.0 1.2399e-01 1.0 1.95e+07 1.0 0.0e+00 0.0e+00 0.0e+00 2 1 0 0 0 9 2 0 0 0 158
> VecScale 1013 1.0 9.9998e-02 1.0 9.73e+06 1.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 7 1 0 0 0 97
> VecCopy 208 1.0 3.9999e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecSet 45 1.0 7.9989e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
> VecAXPY 233 1.0 3.9999e-03 1.0 1.68e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 419
> VecWAXPY 33 1.0 3.9990e-03 1.0 3.17e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 79
> VecMAXPY 1013 1.0 2.9199e-01 1.0 3.14e+08 1.0 0.0e+00 0.0e+00 0.0e+00 5 15 0 0 0 21 30 0 0 0 1074
> VecPointwiseMult 988 1.0 9.5995e-02 1.0 9.42e+06 1.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 7 1 0 0 0 98
> VecScatterBegin 13 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecReduceArith 2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecReduceComm 1 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecCUDACopyTo 24 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecCUDACopyFrom 21 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatMult 1013 1.0 1.3600e-01 1.0 3.83e+08 1.0 0.0e+00 0.0e+00 0.0e+00 2 18 0 0 0 10 37 0 0 0 2815
> MatMultTranspose 8 1.0 3.9999e-03 1.0 1.15e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 29
> MatAssemblyBegin 10 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatAssemblyEnd 10 1.0 8.0001e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
> MatZeroEntries 10 1.0 4.0002e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatFDColorApply 10 1.0 8.7998e-02 1.0 1.26e+07 1.0 0.0e+00 0.0e+00 0.0e+00 2 1 0 0 0 6 1 0 0 0 143
> MatFDColorFunc 210 1.0 1.2000e-02 1.0 1.15e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 1 0 0 0 958
> SNESSolve 1 1.0 1.4160e+00 1.0 1.04e+09 1.0 0.0e+00 0.0e+00 0.0e+00 25 50 0 0 0 100100 0 0 0 737
> SNESLineSearch 2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> SNESFunctionEval 3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> SNESJacobianEval 2 1.0 9.1998e-02 1.0 1.27e+07 1.0 0.0e+00 0.0e+00 0.0e+00 2 1 0 0 0 6 1 0 0 0 138
> KSPGMRESOrthog 980 1.0 8.3199e-01 1.0 5.89e+08 1.0 0.0e+00 0.0e+00 0.0e+00 15 28 0 0 0 59 56 0 0 0 708
> KSPSetup 2 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> KSPSolve 2 1.0 1.3240e+00 1.0 1.03e+09 1.0 0.0e+00 0.0e+00 0.0e+00 23 49 0 0 0 93 99 0 0 0 778
> PCSetUp 2 1.0 3.9999e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> PCApply 980 1.0 9.5995e-02 1.0 9.41e+06 1.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 7 1 0 0 0 98
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100831/83af605f/attachment.html>
