[petsc-dev] [GPU] Performance on Fermi
    Keita Teranishi
    keita at cray.com
    Fri Aug 27 16:06:30 CDT 2010
Barry,
The CPU timing I reported was after recompiling the code (I removed PETSC_USE_DEBUG and GDB macros from petscconf.h).
 Keita Teranishi
 Scientific Library Group
 Cray, Inc.
 keita at cray.com
-----Original Message-----
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Barry Smith
Sent: Friday, August 27, 2010 3:37 PM
To: For users of the development version of PETSc
Subject: Re: [petsc-dev] [GPU] Performance on Fermi
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
  You need to build the code with ./configure --with-debugging=0 to make a far comparison. This will speed up the CPU version.
   Barry
On Aug 27, 2010, at 2:22 PM, Keita Teranishi wrote:
> Barry,
> CPU version takes another digit. So it is 1.6 sec on Fermi and 17 sec 1 core CPU.
> Thanks,
>  Keita Teranishi
>  Cray, Inc.
>  keita at cray.com
> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Keita Teranishi
> Sent: Friday, August 27, 2010 2:20 PM
> Barry,
> Yes. It improves the performance dramatically, but the execution time for KSPSolve stays the same.
> MatMult 5.2 Gflops
> Thanks,
>  Keita Teranishi
>  Cray, Inc.
>  keita at cray.com
> Sent: Friday, August 27, 2010 2:15 PM
> Subject: [petsc-dev] [GPU] Performance on Fermi
>   PETSc-dev folks,
>      Please prepend all messages to petsc-dev that involve GPUs with [GPU] so they can be easily filtered.
>    Keita,
>      To run src/ksp/ksp/examples/tutorials/ex2.c with CUDA you need the flag -vec_type cuda
>      Note also that this example is fine for simple ONE processor tests but should not be used for parallel testing because it does not do a proper parallel partitioning for performance
>    Barry
> On Aug 27, 2010, at 2:04 PM, Keita Teranishi wrote:
>> Hi,
>> I ran ex2.c with a matrix from 512x512 grid.
>> I set CG and Jacobi for the solver and preconditioner.
>> GCC-4.4.4 and CUDA-3.1 are used to compile the code.
>> BLAS and LAPAKCK are not optimized.
>> MatMult
>> Fermi: 		1142 MFlops
>> 1 core Istanbul:	420 MFlops
>> KSPSolve:
>> Fermi:			1.5 Sec
>> 1 core Istanbul:	1.7 Sec
>> Keita Teranishi
>> Cray, Inc.
>> keita at cray.com
>> [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Satish Balay
>> Sent: Friday, August 27, 2010 1:49 PM
>> Subject: Re: [petsc-dev] Problem with petsc-dev
>> On Fri, 27 Aug 2010, Satish Balay wrote:
>>> There was a problem with tarball creation for the past few days. Will
>>> try to respin manually today - and update you.
>> the petsc-dev tarball is now updated on the website..
>> Satish
