[petsc-dev] [petsc4py] Vec.getArray()
    Lisandro Dalcin
    dalcinl at gmail.com
    Fri Aug 27 13:14:02 CDT 2010
I cannot figure out how to implement a copy-free and safe
VecGetArray()/VecRestoreArray() pattern in Python (not even by using
the 'with' statement, it leaks the target variable!!!!).
1) Provide a 100% safe but slow, copy-based way:
a = x.getArray() #gives you a copy. It is implemented with
VecGetArrayRead(x, &p), memcpy p->a.data, VecRestoreArray(x,&p) on a
freshly allocated numpy array that is returned to the user.
a.base is None # True, the array owns its memory buffer
x.setArray(a) #writes array on the vector. It is implemented with
VecGetArray(x,&p) and memcpy a.data -> p, VecRestoreArray(x,&p)
2) Provide a unsafe but fast, copy-free way to get a numpy array
sharing memory with PETSc vectors:
a = numpy.asarray(x) # gives you a numpy array that shares mem with
the vec, it is implemented with VecGetArray() and special Python/NumPy
protocols for buffer sharing.
a.base is x # True, the base attr holds a ref to the Vec instance, the
array does not own its memory buffer.
del a # force garbage collection explicitily, then VecRestoreArray()
will be called when a gets deallocated.
Relying in explicit use of del for garbage collection is not reliable.
NumPy is designed to support array views, these views hold references
to the base array. So users have to be very careful about how the
arrays obtained the fast way are used.
Comments ? Suggestions? Complaints?
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
