[petsc-dev] What's the point of D(A/M)GetGlobalVector?
    Aron Ahmadia
    aron.ahmadia at kaust.edu.sa
    Fri Aug 27 06:47:29 CDT 2010
Thanks Matt and Jed,
I think I'm straight on usage/philosophy here.
A
On Fri, Aug 27, 2010 at 2:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Simply, in PETSc, getFoo() and restoreFoo() operate an object pool.
>    Matt
> On Fri, Aug 27, 2010 at 11:23 AM, Jed Brown <jed at 59a2.org> wrote:
>> On Fri, 27 Aug 2010 14:13:01 +0300, Aron Ahmadia <
>> aron.ahmadia at kaust.edu.sa> wrote:
>> > What exactly is the purpose of these routines then?  Is there a global
>> > Vector associated with a DA?  If so, why are the values uninitialized?
>> It's common to need work vectors in places like residual evaluation and
>> Jacobian assembly.  There is a little bit of setup cost to allocate a
>> new vector each time, so usually we'd prefer that they be persistent and
>> just reuse them.  One option would be to make the user manage this
>> themselves, but that's error prone because it's easy to accidentally
>> alias the work vectors, so instead the DA keeps a cache of vectors.  It
>> starts out empty, and each time you call DAGetGlobalVector(), the cache
>> is searched for an available vector.  If none are found, a new one is
>> allocated and the cache grows by one.  DARestoreGlobalVector() checks a
>> vector back in so it may be used elsewhere.  These vectors are destroyed
>> in DADestroy().
>> Jed
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100827/dcd73c11/attachment.html>
