[petsc-dev] no module named cmakegen
Jed Brown jed at 59A2.org
Mon Aug 23 17:38:30 CDT 2010
On Mon, 23 Aug 2010 17:21:52 -0500 (CDT), Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 23 Aug 2010, Satish Balay wrote:
> > Now that there are more and more standalone scripts - perhaps we need
> > a better consistant way to handle this - but I don't know what that
> > is..
> mercurial way is to have 'hg' be the frontend script to all commands.
> i.e no invocation of individual scripts ..
> Perhaps we should adopt that?
Interesting idea.  Have one top-level "petscconf" with subcommands to
configure, build (via make, builder.py, cmake), interrogate for linking
options, etc.
Matt, it doesn't require modification of PYTHONPATH since you would use
the path in which the executable resides (may or may not be
"installed").  You wouldn't normally put the executable in your path,
instead run
  /path/to/installed-or-not/petsc-x.y/petscconf subcommand --options
The only thing you couldn't do is to move petscconf to some other
location (independent of the rest of the PETSc tree).
This begs the question of how PETSC_ARCH would be handled.  Either there
would be separate top-level script for ARCH-specific and ARCH-agnostic
functionality, or PETSC_ARCH would need to remain an environment or
otherwise specified configuration variable.
Jed
