[petsc-dev] Stop breaking my build
    Satish Balay
    balay at mcs.anl.gov
    Thu Aug 19 13:48:35 CDT 2010
On Thu, 19 Aug 2010, Matthew Knepley wrote:
> On Thu, Aug 19, 2010 at 5:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > We expect all our users to send complete logs - whenreporting
> > problems.  we as developers should be able to include atleat minimal
> > realvent info in such e-mails - which is the configure command used.
> I did not see the point here since we are all developers and know
> that 'complex' is broken from the error message. And I fixed the
> breakage twice before this.
I guess I should have read error messages properly..
Shri - looks like merit should be PetscReal - not PetscComplex [pusing
a fix for this. If this is incorrect - you can revert my change]
Satish
