[petsc-dev] Stop breaking my build
    Satish Balay
    balay at mcs.anl.gov
    Thu Aug 19 12:33:05 CDT 2010
Matt,
Nobody knows how you build stuff. Atleast mention the configure
command used so it can be reproduced and fixed..
Satish
On Thu, 19 Aug 2010, Matthew Knepley wrote:
> libfast in: /PETSc3/petsc/petsc-dev/src/snes/impls/lsvi
> lsvi.c: In function 'PetscErrorCode SNESLSVIComputeMeritFunction(_p_Vec*,
> PetscScalar*)':
> lsvi.c:137: error: no matching function for call to 'VecNormBegin(_p_Vec*&,
> NormType, PetscScalar*)'
> /PETSc3/petsc/petsc-dev/include/petscvec.h:468: note: candidates are:
> PetscErrorCode VecNormBegin(_p_Vec*, NormType, PetscReal*)
> /PETSc3/petsc/petsc-dev/include/petscvec.h:469: note:
> PetscErrorCode VecNormBegin(_p_Vec*, NormType)
> /PETSc3/petsc/petsc-dev/include/petscvec.h:470: note:
> PetscErrorCode VecNormBegin(_p_Vec*)
> lsvi.c:138: error: no matching function for call to 'VecNormEnd(_p_Vec*&,
> /PETSc3/petsc/petsc-dev/include/petscvec.h:471: note: candidates are:
> PetscErrorCode VecNormEnd(_p_Vec*, NormType, PetscReal*)
> /PETSc3/petsc/petsc-dev/include/petscvec.h:472: note:
> PetscReal VecNormEnd(_p_Vec*, NormType)
> /PETSc3/petsc/petsc-dev/include/petscvec.h:473: note:
> PetscReal VecNormEnd(_p_Vec*)
> lsvi.c: In function 'PetscErrorCode SNESLSVIComputeSSFunction(_p_SNES*,
> _p_Vec*, _p_Vec*)':
> lsvi.c:207: error: no match for 'operator<=' in '*(((PetscScalar*)(((long
> unsigned int)i) * 16ul)) + l) <= -1.0e+20'
> lsvi.c:207: error: no match for 'operator>=' in '*(((PetscScalar*)(((long
> unsigned int)i) * 16ul)) + u) >= 1.0e+20'
> lsvi.c:210: error: no match for 'operator<=' in '*(((PetscScalar*)(((long
> lsvi.c:215: error: no match for 'operator>=' in '*(((PetscScalar*)(((long
> SNESLSVIComputeBsubdifferential(_p_SNES*, _p_Vec*, _p_Vec*, _p_Mat*,
> _p_Mat*, MatStructure*)':
> lsvi.c:279: error: no match for 'operator<=' in '*(((PetscScalar*)(((long
> lsvi.c:279: error: no match for 'operator>=' in '*(((PetscScalar*)(((long
> lsvi.c: In function 'PetscErrorCode SNESLSVICheckDescentDirection(_p_SNES*,
> _p_Vec*, _p_Vec*, PetscTruth*)':
> lsvi.c:360: error: no matching function for call to 'VecNormBegin(_p_Vec*&,
> lsvi.c:361: error: no matching function for call to 'VecNormEnd(_p_Vec*&,
> lsvi.c:365: error: no match for 'operator>' in 'dpsidotY > rhs'
> lsvi.c: In function 'PetscErrorCode SNESSolve_LSVI(_p_SNES*)':
> lsvi.c:469: error: cannot convert 'PetscScalar' to 'PetscReal' in assignment
> lsvi.c:471: error: cannot convert 'PetscScalar' to 'double' in assignment
> lsvi.c:472: error: cannot convert 'PetscScalar' to 'PetscReal' in argument
> passing
> lsvi.c:475: error: cannot convert 'std::complex<double>' to 'PetscReal' in
> assignment
> lsvi.c:477: error: cannot convert 'PetscScalar' to 'PetscReal' in argument
> passing
> lsvi.c:521: error: cannot convert 'PetscScalar' to 'PetscReal' in assignment
> lsvi.c:522: error: cannot convert 'PetscScalar' to 'PetscReal' in argument
> passing
> lsvi.c:523: warning: cannot pass objects of non-POD type 'struct
> PetscScalar' through '...'; call will abort at runtime
> lsvi.c:545: error: cannot convert 'PetscScalar' to 'PetscReal' in assignment
> lsvi.c:551: error: cannot convert 'PetscScalar' to 'PetscReal' in argument
> passing
> ar: lsvi.o: No such file or directory
>    Matt
