[petsc-dev] PetscDLSym called on an empty handle
    Lisandro Dalcin
    dalcinl at gmail.com
    Thu Aug  5 16:00:39 CDT 2010
On 5 August 2010 13:40, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> What is the intended behavior of PetscDLSym when called on an empty handle:
> PetscDLSym(handle=PETSC_NULL, symbol, &value)
> My understanding was that this should look for symbol in the symbol table of
> the main executable.
> This is based on what happens in the Windows case (#ifdef
> PETSC_HAVE_WINDOWS_H),
> but when using dlopen (#ifdef PETSC_HAVE_DLFCN_H), this probably won't
> behave correctly,as currently implemented.
> This is because the above call will boil down to
>    value = dlsym((dlhandle_t)0, symbol),
> which on many systems returns NULL (e.g., on Ubuntu 9.10).
Look at your dlfch.h header file.. Does it have the line below?:
# define RTLD_DEFAULT	((void *) 0)
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
