[petsc-dev] PetscDLSym called on an empty handle
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Thu Aug  5 11:47:30 CDT 2010
On Thu, Aug 5, 2010 at 11:42 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Aug 5, 2010 at 11:40 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>> What is the intended behavior of PetscDLSym when called on an empty
>> handle: PetscDLSym(handle=PETSC_NULL, symbol, &value)
>> My understanding was that this should look for symbol in the symbol table
>> of the main executable.
>> This is based on what happens in the Windows case (#ifdef
>> PETSC_HAVE_WINDOWS_H),
>> but when using dlopen (#ifdef PETSC_HAVE_DLFCN_H), this probably won't
>> behave correctly,as currently implemented.
>> This is because the above call will boil down to
>>    value = dlsym((dlhandle_t)0, symbol),
>> which on many systems returns NULL (e.g., on Ubuntu 9.10).
>> There is a relatively easy fix, which is to obtain the handle of the main
>> executable with, for example,
>>   dlhandle = dlopen(0,RTLD_LOCAL|RTLD_LAZY)
>> followed by
>>   value = dlsym(dlhandle,symbol)
>> I have played around with it on my box, and it appears to work.
>> I can push that fix, if that's what we decide we want, and if it doesn't
>> alter the currently expected behavior.
>> There is one caveat: symbols can be dlsym'ed from the executable only if
>> they are exported as dynamically-loadable,
>> which is not the default behavior for linking executable (so as not to
>> pollute the dynamic symbol table).
>> On linux the linker needs to get -Wl,--export-dynamic, but it would be
>> nice to enable some sort of portable option at compile time.
> This is sharedLinkerFlags.
Sorry, I meant configure-time option.
Does sharedLinkerFlags alter the behavior of CLINKER?
Unless there is another way to link an executable.
Dmitry.
>   Matt
>> Incidentally, currently there appears to be no way to supply additional
>> linker flags, as used to be the case with LDFLAGS.
>> Dmitry.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100805/b3fa10ca/attachment.html>
