PetscTrMallocDefault(): possible buffer overrun
Wed Sep 16 07:58:34 CDT 2009
   Lisandro,
     You are right; some sloppy stuff here. Back when PetscScalar was
a double and a long an int :-) and before PetscCookie existed.
     Here is what I suggest, change the two cookie locations to be
declared to be PetscCookie (why not use that type since we have it?)
then you can use sizeof(union{PetscCookie,PetscScalar}) for the extra
space.
I think the original motivation for allocating sizeof(PetscScalar) in
the end location was so that allocated chunks were multiplies of
PetscScalar length.
I am not sure if that is important now. Maybe you can just use
sizeof(PetscCookie) for the extra space?
     Sound ok?
     Barry
On Sep 15, 2009, at 9:07 PM, Lisandro Dalcin wrote:
> Barry, please consider Linux 64 bits (but not Win64) and a real,
> single precision PetscScalar (i.e. C "float"). Then in this scenario
> sizeof(long) is 8 and sizeof(PetscScalar) is 4.
> Now, go to PetscTrMallocDefault() and notice the extra
> sizeof(PetscScalar) allocated to save the sentinel cookie at the end
> of the buffer. Next, let's see the actual line storing the sentinel
> value:
> *(unsigned long *)(inew + nsize) = COOKIE_VALUE;
> Perhaps I'm missing something, but this seems to be a buffer overrun:
> 8 bytes (unsigned long) will be written, but only 4 bytes (float) were
> allocated... Again this is for the very specific combination of Linux
> (OS X?) 64 bits and real single precision PetscScalar. Perhaps we
> should allocate sizeof(union{long,PetscScalar}) instead of just
> sizeof(PetscScalar) ??
> IIUC, you were the author of this stuff. Then, it would be great if
> you could review this :-)
> Thanks,
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
