ML symbols in petscksp.so
Matthew Knepley
knepley at gmail.com
Wed Oct 28 16:27:08 CDT 2009
On Wed, Oct 28, 2009 at 4:14 PM, Jed Brown <jed at 59a2.org> wrote:
> Matthew Knepley wrote:
> > You always have to link the ML library if you configure for ML, right?
> No, all the third party libs used to be put into the PETSc shared libs
> (but not the static libs). The easiest way to do this is with
> -Wl,--whole-archive though I haven't looked at the build system to see
> if this is how it is actually being done. All the others still behave
> this way, but ML is no longer included.
Wenever did this, and satill don't. We use -rpath, so that you can track
back to
the associated shared library, if it exists.
Matt
> So if you are using shared libs, you only need to link libpetsc*.so.
> This is recommended practice with shared libs, you only explicitly link
> the interface libraries (those that your code actually calls into) and
> let the linker handle the dependencies. Of course when using static
> libs, you need to explicitly link all the dependencies.
> Jed
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091028/d42e85c7/attachment.html>
