changes for PetscMap
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Oct 27 16:37:43 CDT 2009
    PetscMap is a strange beast in PETSc.
1) it is not a PetscObject (that is it has no PETSc header)
2) it is used as a PetscMap* instead of PetscMap like most objects
3) it does not have a PetscMapCreate() instead it has a
PetscMapInitialize() which is like a create except it does not malloc
its memory
4) It does have a PetscMapDestroy() that DOES free the space.
5) Sometimes a PetscMalloc() is called before PetscMapInitialize() and
sometimes a PetscMap is declared and a & of the variable is passed in
     In this case it will crash if one calls PetscMapDestroy() is
called on it. So instead one must call PetscFree(map->range); to free
the interior space.
   This strange creature evolved over time because I did not want
PetscMap to be a full heavy weight object, but it pretty much ended up
being one anyways (for example it has reference counting). For a long
time I hid PetscMap in the less public part of PETSc didn't want most
people to have to deal with it.
    I still don't want it to be something most PETSc users need ever
see, but it is time to fix it up and make it more consistent with
other objects. So I propose to make a PetscMap just like other PETSc
objects, with create(), destroy(), opaque definition except I will
still not make it have a PETSc header. This will not require much
change in the code but will simplify its usage.
   Any comments.
    Barry
