Subsecond sleep
Jed Brown jed at 59A2.org
Sun Oct 18 13:20:54 CDT 2009
Barry Smith wrote:
>   It is fine with me to switch the infrastructure to use a PetscReal
> instead of integer
Done.
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/5704078f5057
Did PetscSleep() once return the time remaining instead of an error
code?  The following can't possibly have worked correctly for a while.
Should it be fixed or removed?
        IBM sleep may return at anytime, hence must see if there is more time to sleep
      int left = sleeptime;
      while (left > 0) {left = PetscSleep(left) - 1;}
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091018/ea43da9b/attachment.sig>
