-malign-double
Jed Brown
jed at 59A2.org
Mon Nov 16 16:12:48 CST 2009
Barry Smith wrote:
> What about have configure look for uintptr_t if it does not exist
> then have configure check if unsigned long long is large enough, if not
> try size_t otherwise barf?
You're right, the compiler will warn about casting the pointer to an
integer of different size, as in
char *Align(char *ptr) {
unsigned low = 0xf & (unsigned)ptr;
return ptr - low + ((low+0xf) & ~0xf);
although I think this is actually okay (we are explicitly truncating it
further, and I think it is guaranteed that the truncation preserves the
low byte).
By barf I assume you mean just skip the alignment fix-up.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091116/76e6dfe1/attachment.sig>
