Any idea what's going on on Cygwin?
Lisandro Dalcin
dalcinl at gmail.com
Tue Mar 31 21:09:24 CDT 2009
After a configure & make, make test failed because of broken libs.
I've noticed this:
$ grep 'ar:' cygwin-c-debug/conf/make.log
/usr/bin/ar: eisen.o: No such file or directory
/usr/bin/ar: pythonts.o: No such file or directory
/usr/bin/ar: dacorn.o: No such file or directory
Then I've manually ran "make ACTION=libfast tree -C src/some/path" to
re-run make on the dirs where these files are located... But now, no
errors.... and after that, at least the C test from "make test"
worked...
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
