MatMult_Scatter woes
Jed Brown
jed at 59A2.org
Mon Mar 30 05:52:21 CDT 2009
The current implementation of MatMult_Scatter and
MatMultTranspose_Scatter do not actually have matrix semantics unless
the index sets are permutations. For example, it's generally desirable
that
MatMult(A,x,y);
agrees with
VecZeroEntries(y);
MatMultAdd(A,x,y,y);
Similarly for MatMultTranspose. In addition, MatMultTranspose should
actually be the transpose of MatMult. Consider the scatter defined by
scatter : x -> y
isx = [0 0]
isy = [0 1]
where x has length 1 and y has length 2. This forward scatter is
equivalent to a 2x1 matrix A = [1;1]
Indeed A*[1] = [1;1]
but A'*[1;1] = [2]
where as MatMultTranspose_Scatter(A,y=[1;1],x) gives x=[1].
This can be corrected by changing the body of MatMultTranspose_Scatter
from
ierr = VecScatterBegin(scatter->scatter,x,y,INSERT_VALUES,SCATTER_REVERSE);CHKERRQ(ierr);
ierr = VecScatterEnd(scatter->scatter,x,y,INSERT_VALUES,SCATTER_REVERSE);CHKERRQ(ierr);
to
ierr = VecZeroEntries(y);CHKERRQ(ierr);
ierr = VecScatterBegin(scatter->scatter,x,y,ADD_VALUES,SCATTER_REVERSE);CHKERRQ(ierr);
ierr = VecScatterEnd(scatter->scatter,x,y,ADD_VALUES,SCATTER_REVERSE);CHKERRQ(ierr);
and similarly for MatMult_Scatter.
Unfortunately, these modifications roughly double the cost of typical
sequential scatters and could be much worse (scattering from a small
vector to a very large one). I think that correctness is more important
here and users would typically not use MatScatter when this would have
significant impact or when INSERT_VALUES semantics are desired. Of
course some performance can be recovered by having MatScatter use
INSERT_VALUES when the destination index set is a permutation.
Also, what is the ssh url for the repo? I've tried some variations on
ssh://petsc@petsc.cs.iit.edu/petsc/petsc-dev without success.
Jed
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090330/e5fffb2a/attachment.sig>
