building PETSc on Windows
Matthew Knepley
knepley at gmail.com
Mon Mar 23 09:48:30 CDT 2009
On Mon, Mar 23, 2009 at 8:23 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> The Cygwin way works, but let me say that it is a bit of pain... as a
> novice in this crapy environment, I've spent a lot of time just to get
> all the Cygwin stuff properly installed...
> I'm exploring the possibility of using an alternative, that is, using
> stock Python for Windows + MinGW + MSYS. MSYS provides a minimal
> UNIX-like shell and bundles development utilities like make. IMHO, it
> is a much lighter approach to Cygwin... I believe the alternative is
> possible... However, I have some issues that have to be addressed, and
> I would need your help...
> 1) As I'm using the stock Python for Windows, the "select" module does
> not work on pipes.. Then the machinery for executing things in the
> shell and get stdout and stderr stuff needs to be reeimplemented... Do
> not worry about this, I can take this.
> 2) BuildSystem assumes that the shell is '/bin/sh'... I would need it
> to find "sh" in the $PATH instead...
Where is this assumption? In BuildSystem/config/programs.py we explicitly
search for 'sh', so it is available, we just need to use it everywhere.
> 3) When checking for make, BuildSystem uses 'strings' somewhere..
> Again, I need strings to be searched in $PATH.
Okay, I fixed this.
Matt
> Can any of you try to fix (2) and (3) ? Anyway, that would be a good
> change even for Unix-like systems, right?
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090323/8ae99161/attachment.html>
