script to query PETSc makefile variables?
    Matthew Knepley
    knepley at gmail.com
    Thu Jan 22 18:34:30 CST 2009
I will split it into two pieces. One with a nice interface, that only
works in the
source directories OR if you install BuildSystem, and one that does nothing
but return a variable value.
  Matt
On Thu, Jan 22, 2009 at 6:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Matt,
>    I don't understand. If PETSc is --prefix installed then configVars.py
> will not work?
> So what good is it's nice help system if it don't work? Either
> 1) configVars.py should not be recommend as a way to get PETSc values or
> 2) configVars.py should be fixed so that it can get PETSc values by
>    a) either removing its dependencies on things that are not there when
> someone
>         wants to use it (that is its dependency on script)
>    b) anything that configVars.py needs to work must be --prefix installed
> when PETSc
>         is installed (I don't like the idea of needing the entire
> BuildSystem shoved in when
>         PETSc is --prefix installed, this is why I suggested a). Maybe only
> script stuff needs
>         to be --prefix installed with PETSc).
>   Barry
> On Jan 22, 2009, at 6:20 PM, Matthew Knepley wrote:
>> On Thu, Jan 22, 2009 at 6:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Jan 22, 2009, at 6:17 PM, Matthew Knepley wrote:
>>>> I meant something slightly different. I mean that the 'script' module
>>>> is really doing very
>>>> little work in this example. It is only processing command line
>>>> options. Retreiving the
>>>> variables will work with only standard Python.
>>>  So take out the dependency.
>> I like it for this example. It allows a nice help system and will
>> always work since this
>> code is in PETSc. If you want to take the code out, then its your
>> responsibility to
>> take out 'script' as well.
>>  Matt
>>>  Barry
>>>> Matt
>>>>> Boyana
>>>>>> Matt
>>>>>>> Boyana
>>>>>>>> On Thu, Jan 22, 2009 at 5:15 PM, Boyana Norris <norris at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>>> Thank you both -- I'd prefer to use configVars.py, but it seems to
>>>>>>>>> depend
>>>>>>>>> on
>>>>>>>>> the script module, which is not standard in at least Python 2.5.
>>>>>>>>> Googling
>>>>>>>>> for "python script module" is a joke, as you can imagine. Is this a
>>>>>>>>> PETSc
>>>>>>>>> thing or a general module I can get somewhere?
>>>>>>>> That module is in PETSc,
>>>>>>>> $PETSC_DIR/config/BuildSystem
>>>>>>>> Matt
>>>>>>>>> Thanks!
>>>>>>>>> Boyana
>>>>>>>>>> Check out $PETSC_DIR/bin/configVars.py
>>>>>>>>>> Matt
>>>>>>>>>> On Thu, Jan 22, 2009 at 4:38 PM, Satish Balay <balay at mcs.anl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Thu, 22 Jan 2009, Boyana Norris wrote:
>>>>>>>>>>>> Is there a script that can be used to query the values of
>>>>>>>>>>>> various
>>>>>>>>>>>> variables
>>>>>>>>>>>> defined in petscvariables makefile snippets (similar to lots of
>>>>>>>>>>>> linux
>>>>>>>>>>>> tools'
>>>>>>>>>>>> pkg-config scripts)?
>>>>>>>>>>> [don't have canned code for this but] I've previously recommended
>>>>>>>>>>> doing the following in the packages configure.. [facets now has
>>>>>>>>>>> this
>>>>>>>>>>> in their configure to detect petsc]
>>>>>>>>>>> - petsc_arch and petsc_dir are inputs to configure
>>>>>>>>>>> - Create a dummy makefile on the fly
>>>>>>>>>>> - run this makefile to echo relavent stuff..
>>>>>>>>>>> For eg:
>>>>>>>>>>> asterix:/home/balay/download-pine>cat configpetsc.sh
>>>>>>>>>>> #!/bin/sh
>>>>>>>>>>> PETSC_ARCH=asterix64
>>>>>>>>>>> PETSC_DIR=/home/balay/spetsc
>>>>>>>>>>> cat <<EOF > petscmake
>>>>>>>>>>> PETSC_ARCH = ${PETSC_ARCH}
>>>>>>>>>>> PETSC_DIR  = ${PETSC_DIR}
>>>>>>>>>>> include ${PETSC_DIR}/conf/base
>>>>>>>>>>> EOF
>>>>>>>>>>> PETSC_INC=`make -f petscmake getincludedirs`
>>>>>>>>>>> PETSC_LIB=`make -f petscmake getlinklibs`
>>>>>>>>>>> echo '**** PETSC_INC ***'
>>>>>>>>>>> echo ${PETSC_INC}
>>>>>>>>>>> echo '**** PETSC_LIB ***'
>>>>>>>>>>> echo ${PETSC_LIB}
>>>>>>>>>>> Satish
>>>>>>>>> Boyana Norris, Computer Scientist    |   Email: norris at mcs.anl.gov
>>>>>>>>> Argonne National Laboratory          |   Phone: +1 (630) 252 7908
>>>>>>>>> http://www.mcs.anl.gov/~norris/      |   Fax:   +1 (630) 252 5986
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which
>>>> their experiments lead.
>>>> -- Norbert Wiener
>> -- Norbert Wiener
-- Norbert Wiener
