script to query PETSc makefile variables?
Matthew Knepley
knepley at gmail.com
Thu Jan 22 18:20:20 CST 2009
On Thu, Jan 22, 2009 at 6:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 22, 2009, at 6:17 PM, Matthew Knepley wrote:
>> I meant something slightly different. I mean that the 'script' module
>> is really doing very
>> little work in this example. It is only processing command line
>> options. Retreiving the
>> variables will work with only standard Python.
> So take out the dependency.
I like it for this example. It allows a nice help system and will
always work since this
code is in PETSc. If you want to take the code out, then its your
responsibility to
take out 'script' as well.
Matt
> Barry
>> Matt
>>> Boyana
>>>> Matt
>>>>> Boyana
>>>>>> On Thu, Jan 22, 2009 at 5:15 PM, Boyana Norris <norris at mcs.anl.gov>
>>>>>> wrote:
>>>>>>> Thank you both -- I'd prefer to use configVars.py, but it seems to
>>>>>>> depend
>>>>>>> on
>>>>>>> the script module, which is not standard in at least Python 2.5.
>>>>>>> Googling
>>>>>>> for "python script module" is a joke, as you can imagine. Is this a
>>>>>>> PETSc
>>>>>>> thing or a general module I can get somewhere?
>>>>>> That module is in PETSc,
>>>>>> $PETSC_DIR/config/BuildSystem
>>>>>> Matt
>>>>>>> Thanks!
>>>>>>> Boyana
>>>>>>>> Check out $PETSC_DIR/bin/configVars.py
>>>>>>>> Matt
>>>>>>>> On Thu, Jan 22, 2009 at 4:38 PM, Satish Balay <balay at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>>> On Thu, 22 Jan 2009, Boyana Norris wrote:
>>>>>>>>>> Is there a script that can be used to query the values of various
>>>>>>>>>> variables
>>>>>>>>>> defined in petscvariables makefile snippets (similar to lots of
>>>>>>>>>> linux
>>>>>>>>>> tools'
>>>>>>>>>> pkg-config scripts)?
>>>>>>>>> [don't have canned code for this but] I've previously recommended
>>>>>>>>> doing the following in the packages configure.. [facets now has
>>>>>>>>> this
>>>>>>>>> in their configure to detect petsc]
>>>>>>>>> - petsc_arch and petsc_dir are inputs to configure
>>>>>>>>> - Create a dummy makefile on the fly
>>>>>>>>> - run this makefile to echo relavent stuff..
>>>>>>>>> For eg:
>>>>>>>>> asterix:/home/balay/download-pine>cat configpetsc.sh
>>>>>>>>> #!/bin/sh
>>>>>>>>> PETSC_ARCH=asterix64
>>>>>>>>> PETSC_DIR=/home/balay/spetsc
>>>>>>>>> cat <<EOF > petscmake
>>>>>>>>> PETSC_ARCH = ${PETSC_ARCH}
>>>>>>>>> PETSC_DIR = ${PETSC_DIR}
>>>>>>>>> include ${PETSC_DIR}/conf/base
>>>>>>>>> EOF
>>>>>>>>> PETSC_INC=`make -f petscmake getincludedirs`
>>>>>>>>> PETSC_LIB=`make -f petscmake getlinklibs`
>>>>>>>>> echo '**** PETSC_INC ***'
>>>>>>>>> echo ${PETSC_INC}
>>>>>>>>> echo '**** PETSC_LIB ***'
>>>>>>>>> echo ${PETSC_LIB}
>>>>>>>>> Satish
>>>>>>> Boyana Norris, Computer Scientist | Email: norris at mcs.anl.gov
>>>>>>> Argonne National Laboratory | Phone: +1 (630) 252 7908
>>>>>>> http://www.mcs.anl.gov/~norris/ | Fax: +1 (630) 252 5986
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
-- Norbert Wiener
