script to query PETSc makefile variables?
    Boyana Norris
    norris at mcs.anl.gov
    Thu Jan 22 17:15:41 CST 2009
Thank you both -- I'd prefer to use configVars.py, but it seems to
depend on the script module, which is not standard in at least Python
2.5. Googling for "python script module" is a joke, as you can imagine.
Is this a PETSc thing or a general module I can get somewhere?
Thanks!
Boyana
Matthew Knepley wrote:
> Check out $PETSC_DIR/bin/configVars.py
>   Matt
> On Thu, Jan 22, 2009 at 4:38 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Thu, 22 Jan 2009, Boyana Norris wrote:
>>> Is there a script that can be used to query the values of various variables
>>> defined in petscvariables makefile snippets (similar to lots of linux tools'
>>> pkg-config scripts)?
>> [don't have canned code for this but] I've previously recommended
>> doing the following in the packages configure.. [facets now has this
>> in their configure to detect petsc]
>> - petsc_arch and petsc_dir are inputs to configure
>> - Create a dummy makefile on the fly
>> - run this makefile to echo relavent stuff..
>> For eg:
>> asterix:/home/balay/download-pine>cat configpetsc.sh
>> #!/bin/sh
>> PETSC_ARCH=asterix64
>> PETSC_DIR=/home/balay/spetsc
>> cat <<EOF > petscmake
>> PETSC_ARCH = ${PETSC_ARCH}
>> PETSC_DIR  = ${PETSC_DIR}
>> include ${PETSC_DIR}/conf/base
>> EOF
>> PETSC_INC=`make -f petscmake getincludedirs`
>> PETSC_LIB=`make -f petscmake getlinklibs`
>> echo '**** PETSC_INC ***'
>> echo ${PETSC_INC}
>> echo '**** PETSC_LIB ***'
>> echo ${PETSC_LIB}
>> Satish
Boyana Norris, Computer Scientist    |   Email: norris at mcs.anl.gov
Argonne National Laboratory          |   Phone: +1 (630) 252 7908
http://www.mcs.anl.gov/~norris/      |   Fax:   +1 (630) 252 5986
