eliminating a cause of my recent rant and argument with Matt
Satish Balay
balay at mcs.anl.gov
Tue Dec 15 15:30:18 CST 2009
Wrt batch mode, the relavent PETSc configure flags are:
'--with-batch=1',
'--with-mpi-shared=0',
'--with-memcmp-ok',
'--sizeof_char=1',
'--sizeof_void_p=4',
'--sizeof_short=2',
'--sizeof_int=4',
'--sizeof_long=4',
'--sizeof_size_t=4',
'--sizeof_long_long=8',
'--sizeof_float=4',
'--sizeof_double=8',
'--bits_per_byte=8',
'--sizeof_MPI_Comm=4',
'--sizeof_MPI_Fint=4',
'--have-mpi-long-double=1',
wrt autoconf - I think these [sizeof stuff] are just shell
variables. The last time I tried doing something equivalnet to
--with-batch - I just set these variables on the command line.
./configure ac_cv_sizeof_long_int=8 ac_cv_sizeof_int=4
etc.. So perhaps the current sizeof_char type options already mimic
autoconf. But if we are using --known-sizeofint=8 type flags - thats
also fine.
The other odd flags are --with-memcmp-ok and --have-mpi-long-double=1
Satish
On Tue, 15 Dec 2009, Barry Smith wrote:
> I think a root of the miscommunication between Matt and I with regard to
> --with-mpi-shared is that --with is used for TWO different reasons
> 1) --with-mpi=0 --with-x=1 etc are used to indicate we want to turn off/on a
> package. In other words they are COMMANDS to BuildSystem
> 2) --with-mpi-shared=1, --with-sizeofint=8 tells BuildSystems FACTS that it
> would normally be figured out by BuildSystem. Usually they are provided on the
> command line because ./configure cannot run compiled programs (using
> --with-batch for example).
> I suggest we can the syntax for 2) and consistently use --known-mpi-shared
> --known-sizeofint=8 etc everywhere in help and BuildSystem. It makes things
> much clearer and can prevent loads of confusion.
> This is likely not compatible with how autoconf does things. Do they have a
> similar split and different names? Is there anything we can copy from their
> approach? Do we care?
> What do others think?
> Barry
