[petsc-maint #38919] Re: stupid, stupid, stupid MPI.py
Lisandro Dalcín dalcinl at gmail.com
Mon Dec 14 10:39:08 CST 2009
On Mon, Dec 14, 2009 at 1:33 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 14, 2009 at 10:28 AM, Lisandro Dalcín <dalcinl at gmail.com> wrote:
>> On Mon, Dec 14, 2009 at 11:34 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > If we are using shared libraries, and the MPI shared library was broken,
>> > the
>> > configure failed. This option was added
>> > to allow the user to turn off that check.
>> What does 'broken' means? How can the lib be broken for configure, but
>> not for linking PETSc or user programs?
> It would also be broken there too, and fall back to the static libraries.
Sorry, I'm still confused. What does 'broken' means? Sorry about my
ignorance: In the case of a corrupted (whatever that could mean)
shared lib file, does the linker fall back to use a static lib?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
