Putting a peculiar multilevel scheme into DMMG?
Jed Brown
jed at 59A2.org
Sun Dec 13 12:55:19 CST 2009
On Sun, 13 Dec 2009 12:01:39 -0600, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Dec 13, 2009, at 11:43 AM, Jed Brown wrote:
> > On Sun, 13 Dec 2009 10:11:07 -0600, Matthew Knepley
> > <knepley at gmail.com> wrote:
> >> Not sure if you would need API additions. Can't everything you
> >> describe be
> >> handled through defining the grid, operator, residual, and
> >> projections?
> > Yes, but DMMG doesn't seem to have an API for setting such things.
> Hmm, doesn't the DMMG make calls on the DM to get those operators?
> So you would provide a DM that provided the custom beasts you want?
You're right, this can be done by replacing dm->ops->refine rather than
providing an API for that manipulation inside of _n_DMMG. I would make
this refinement produce DMs with suitable definitions for
dm->ops->getinterpolation. There is a little nonlocal information in
that my refinement function needs to know when to produce a different
type of DM, but there is no explicit "level" argument. Using
ops->coarsenhierarchy is better in this regard, but it can only be
selected by setting (currently unprefixed) -dmmg_refine 0
-dmmg_hierarchy. Is there a reason the DMRefineHierarchy branch of
DMMGSetDM is commented out? (This is actually the most natural thing
for me.)
> Or is it that the DMMG doesn't have enough of them? That is, it
> does not have a separate function for restriction, for interpolation,
> for residual computer?
That's what I was thinking, but I can just have refinement produce DMs
that know how to do the right thing.
> Regarding how I see DMMG and PCMG. PCMG has the "function slots"
> for what MG needs. DMMG calls methods on the DM to "fill" those
> function slots. The problem is that DMMG is not a PC, so cannot be
> imbedded inside a larger solve; for example wanting to use DMMG on two
> components of that three component problem. My thought was that we
> would move the "filling" behavior of DMMG directly into PCMG (or PC?)
> so that a PCMG has both the "function slots" one can fill manually as
> today or one can provide a DM and the PCMG would use methods on the DM
> to fill up its own "function slots". It is actually a simpler model
> than today with the DMMG and more flexible since the DMMG
> functionality could be used anywhere in a big hierarchy of
> pcfieldsplit, pccomposite, pcmg etc. Now if I could stop sleeping 10
> hours a day and wasting most of my awake time on anxiety I could do
> all this cool shit.
Jed
