problems introduced into TS code
Mon Dec 7 15:05:38 CST 2009
libfast in: /home/buildbot/slave/build/
x86_linux_single_nosched_gcc-4.1_gfortran-4.1_python-2.5_openmpi/PETSc/
dev/default-825/src/ts/impls/explicit/ssp ssp.c: In function
'PetscErrorCode SSPStep_RK_3(_p_TS*, PetscReal, PetscReal, _p_Vec*)':
ssp.c:101: warning: converting to 'PetscInt' from 'double' libfast
dev/default-825/src/ts/impls/implicit libfast in: /home/buildbot/slave/
build/x86_linux_single_nosched_gcc-4.1_gfortran-4.1_python-2.5_openmpi/
PETSc/dev/default-825/src/ts/impls/implicit/beuler libfast in: /home/
dev/default-825/src/ts/impls/implicit/cn libfast in: /home/buildbot/
slave/build/
dev/default-825/src/ts/impls/implicit/theta libfast in: /home/buildbot/
slave/build/
dev/default-825/src/ts/impls/implicit/gl gl.c: In function
'PetscErrorCode TSGLCompleteStep_Rescale(_TSGLScheme*, PetscReal,
_TSGLScheme*, PetscReal, _p_Vec**, _p_Vec**, _p_Vec**)': gl.c:338:
warning: converting to 'PetscInt' from 'PetscReal'
