since developing object oriented software is so cumbersome in C and we are all resistent to doing it in C++
Matthew Knepley
knepley at gmail.com
Sat Dec 5 18:11:58 CST 2009
On Sat, Dec 5, 2009 at 6:01 PM, Jed Brown <jed at 59a2.org> wrote:
> On Sat, 5 Dec 2009 16:50:38 -0600, Matthew Knepley <knepley at gmail.com>
> wrote:
> > You assign a few threads per element to calculate the FEM
> > integral. You could maintain this unassembled if you only need
> > actions.
> You can also store it with much less memory as just values at quadrature
> points.
Depends on the quadrature, but yes there are sometimes better storage
schemes
(especially if you have other properties like decay).
> > However, if you want an actual sparse matrix, there are a couple of
> > options
> > 1) Store the unassembled matrix, and run assembly after integration
> > is complete. This needs more memory, but should perform well.
> Fine, but how is this assembly done? If it's serial then it would be a
> bottleneck, so you still need the concurrent thing below.
Vec assembly can be done on the CPU since its so small I think.
> > 2) Use atmoic operations to update. I have not seen this yet, so I am
> > unsure how is will perform.
> Atomic operations could be used per-entry but this costs on the order of
> 100 cycles on CPUs. I think newer GPUs have atomics, but I don't know
> the cost. Presumably it's at least as much as the latency of a read
> from memory.
Not sure. Needs to be explored. Felipe is working on it.
> When inserting in decent sized chunks, it would probably be worth taking
> per-row or larger locks to amortize the cost of the atomics.
> Additionally, you could statically partition the workload and only use
> atomics for rows/entries that were shared.
You can use partitioning/coloring techniques to increase the lockless
concurrency.
Matt
> Jed
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091205/7662bfc8/attachment.html>
