VecLoadIntoVector and double dispatch
Jed Brown jed at 59A2.org
Fri Dec 4 02:58:48 CST 2009
On Thu, 3 Dec 2009 16:40:10 -0600, Barry Smith <bsmith at mcs.anl.gov> wrote:
>     The vector has a pointer to the DM so the VecView() for that
> derived vector class has access to the DM information.  The same
> viewer object can be used with a bunch of different sized Vecs since
> it gets the DM information out of each vector. With your model when
> the DM info is attached to the viewer you need to pass in a different
> viewer for different vectors (of different sizes). This is just plan
> nuts.
The DM info is not attached to the viewer, I have plain Vecs with a DM
composed so it can call DMView as in your snippet below.  The viewer
holds no state with regard to the DM.  But VecView_MyViewer_DM needs to
get called somehow, it will in turn call DMView and use an internal
Viewer API so that the file has a connection from the Vec to the DM.
>     I say this is nonsense, it ain't more closely coupled to the viewer.
VecGetArray is public, all vectors have to implement it in order to
function in PETSc.  The internal Viewer API to write the bytes of a Vec
with some connection to a DM is not public in the sense that users never
call it directly and no other viewers implement it.  You can substitute
any other Vec and this code will still write it correctly because your
Vec would be broken if it didn't implement VecGetArray [1].
DM currently monkey-patches Vec to set ops->view and
ops->loadintovector, but it doesn't rely on the implementation of Vec
(the definition of Vec_Seq/MPI is never used in src/dm) and in principle
DACreateGlobalVector could call VecSetFromOptions so that it's actually
operating with any Vec type (e.g. the Vec could implement it's
operations on a GPU, only bringing the values to the CPU for
VecGetArray).  Many viewers (formats) have no special representation of
vectors that come from a DM [2] which is the reason for having
ops->viewnative and ops->loadintovectornative.
> >  But somehow, calling VecView needs to be able to call the viewer
> > with enough context for the viewer to wire up the metadata.  Note
> > that the coordinates of the nodes in the DM are part of the vector
> > (it's an ALE formulation) so the metadata is nontrivial.
>     Each vector has a pointer to its DM (DMComposite etc) so its
> viewer can dump/read that info when needed. In fact, when writing a
> vector it could do something like
> myvecview(Vec v,Viewer viewer)
>      DM dm = getreferencetoDMfrom(v);
>      DMView(dm,viewer);
>      ... now dump my vector with writes or whatever
My code looks exactly like this, my point is that the elided part
involves only the public Vec API, but a private Viewer API.  I can put
this chunk of code anywhere, but it needs changes when I make private
changes to the viewer, it doesn't need anything when I make private
changes to the DM or Vec (it doesn't even need to know the types of
those objects).  It is currently sitting with my DM, mostly because I
wrote the DMView first.
> You have to admit that it would be crazy to have the DM viewer method
> stored inside a viewer object which seems to be what your model is.
I wish I could get the dispatch with a symmetric relationship, but in
lieu of that, I don't especially care where the function pointer is,
what matters is that there is a way to get DMView_MyViewer_YourDM
called [3].  As long as dispatch is happening via PetscTypeCompare against
all the known types, we are restricted in that we either have no way to
use a third-party Viewer, or no way to view a third-party DM.  The
current choice is the former; I don't think it's inherently superior,
it's just a choice of which component can be extended without modifying
every object it touches.
If I was distributing a binary-only viewer plugin, I would have no
choice but to put all these methods in with the viewer (but I would
currently have no way to get them called).  Note that a viewer can be
very functional without ever using a private API or looking underneath
obj->data.  With all other PETSc objects (DM not so much because nobody
works with the generic DM interface), I can distribute a binary-only
implementation which is first class after dynamic loading.
My DMView is packaged up with my DM because it needs to know many
internal details of the DM, but the higher level logic about how to
write a time-dependent file with association between Vecs and DMs and
possibly other objects is currently with my viewer.  Now I need to write
DMView_MyViewer_DMComposite, but I won't be able to get it called
without modifying DMComposite (not okay since my viewer is not part of
PETSc).
>     You know my answer. The Viewers are abstractions of file IO, ;
> except instead of having only methods like read()/write() bytes it has
> somewhat "higher level" operations. Note: these methods can include
> graphics operations for example that are still essentially like
> writes(). YOU are making the viewers into these strange "all knowing"
> beasts which I think is wrong.
Current PETSc viewers put minimal metadata and associations into a file,
the application is mostly responsible for "knowing" what was in the file
and wiring everything up correctly.  I'm trying to get more of this in
the file, partly to go with a VisIt plugin that is not tied to a
specific model.  I don't want to maintain a bunch of manual calls to
HDF5 to walk this file in the VisIt plugin especially when this
functionality is useful in other contexts [4].  I also hate C++.  ;-)
So I've been putting stuff like walking the header and attributes to
find out what's there, selecting a time step, etc., into my viewer.  The
viewer is able to offer up information like which fields are available
on which meshes, the plugin is a wrapper that uses this, DMLoadIntoDM
(but not this elegant), VecLoadIntoVector, etc., and stuffs it into
avt/vtk data structures.  Note that this plugin makes no direct calls to
HDF5 and uses only the public API of the Viewer, DM, and Vec.
Jed
[1] In my view, a Vec is just an element of some finite dimensional linear
space.  If you want to use a special format, or stuff extra info in
there to make function evaluation easier or some operation faster,
that's fine, but it's still just an element of this linear space and it
better satisfy the appropriate axioms.  The linear space that this
vector lives in is defined by the DM and we need this to do anything
useful (like visualization) with the vector.
[2] Or the Vec doesn't use information about the DM when viewing on that
format if you like, I think this relationship is symmetric and
conceptually owned by neither.
[3] I think the location of the source for DMView_MyViewer_YourDM is
mostly a packaging and distribution matter rather than a design matter.
I don't see a problem with it being distributed independently of either
MyViewer or YourDM (except for the technical issue of how it announces
it's existence).
[4] It's all slightly complicated by the fact that for visualization,
it's important to be able to read chunks of the domain independently,
whereas the analysis code would prefer to only define proper collective
operations.
