some issues with BuildSystem and LANG
Lisandro Dalcin
dalcinl at gmail.com
Wed Apr 29 11:24:42 CDT 2009
On Wed, Apr 29, 2009 at 12:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Apr 29, 2009 at 10:19 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> What's going on?? My guess was that BuildSystem is not prepared for
>> Spanish words :-)
> What a good guess this is exactly right. I will patch BuildSystem-dev now.
Any chance you can patch BuildSystem for release 3.0.0? Though that
could be problematic, depending on the patch... What are you going to
do to fix the issue?
>> I asked the guy to start the whole process again, but this time begin
>> doing:
>> $ export LANG=en_US.UTF-8
>> and now things worked out of the box...
>> Is this issue documented somewhere? There is anything we can do to
>> improve this? What is the minimal Python version BuildSystem should
>> require? Scanning stdout/stderr for guessing failures is really
>> fragile...
> You would think, but its not nearly as fragile as trusting a stupid
> compiler. Compiler
> people are the most stubborn jackasses in computing. They refuse to consider
> anything
> but
> 1) command line input
> 2) screen message output
> Why bother with APIs when you can have text? No compiler that I know of
> produces
> error codes for warnings, including gcc, so we have no way other than
> scanning the
> output to determine what options are valid (certainly not an interface call
> for this).
> After working on this stuff for a few years, I really really hate people who
> build compilers.
> Some more than others, but all of them are bad.
OK.. I certainly did not know about this...
> Thanks for letting me have my rant time this morning,
You are welcome ;-) ...
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
