MatMult_Scatter woes
Barry Smith
bsmith at mcs.anl.gov
Wed Apr 8 14:23:07 CDT 2009
Perhaps the name MatScatter should then be changed to
MatScatterAdd to clarify the meaning?
I appreciate your arguments.
Here is my issue (which is only indirectly related to this whole
discussion). I an ideal PETSc, I think that if one creates
a VecScatter where two different locations are mapped to the same
output location and then uses it with INSERT_VALUES
I think that should generate an error. To implement this we could have
the scatter create detect this case and set a flag in the scatter,
then if the scatter is used with insert and the flag is set generate
an error. The checking could be wrapped in an #if
defined(PETSC_USE_DEBUGGING).
Barry
On Apr 8, 2009, at 12:30 PM, Jed Brown wrote:
> On Wed 2009-04-08 12:12, Barry Smith wrote:
>> On Apr 8, 2009, at 3:11 AM, Jed Brown wrote:
>>> On Tue 2009-04-07 21:02, Barry Smith wrote:
>>>> Jed,
>>>> Please remind me of what the simplest fix is? Can we just zero
>>>> the
>>>> vector before the scatter for the MatMult and MatMultTranspose?
>>>> What about for MatMultAdd and MatMultTransposeAdd, does anything
>>>> need to
>>>> be done?
>>> The simplest fix is to zero the vector before and always use
>>> ADD_VALUES.
>> Why ADD_VALUES? I don't see that as being any more "correct" then
>> INSERT_VALUES
>> in the case when two different x locations are assigned to a single y
>> location.
> * It is consistent with MatMultAdd
> * It is deterministic when the destination IS is not injective
> * It is equivalent to INSERT_VALUES when the destination IS is
> injective
>> Perhaps the matrix class based on the scatter should have an option
>> allowing the
>> user to determine add or insert? MatScatterSetType()?
> I don't see the point. INSERT_VALUES is an optimization that you can
> use when the destination IS is injective (but really only useful
> when it
> is also surjective so that you can skip VecZeroEntries [*]).
> [*] For some destination IS, nontemporal stores (only possible with
> INSERT_VALUES) might improve cache performance. Such
> (architecture-dependent) cache considerations aside, I would not
> expect
> a performance difference between INSERT_VALUES and ADD_VALUES since
> they
> will be bandwidth limited. This means that INSERT_VALUES is only an
> optimization when the destination IS is bijective so that
> VecZeroEntries can be skipped.
> Jed
