std::complex instantiation
Lisandro Dalcin dalcinl at gmail.com
Mon Sep 8 13:26:53 CDT 2008
In 'src/sys/objects/init.c', we have
#if defined(PETSC_COMPLEX_INSTANTIATE)
template <> class std::complex<double>; /* instantiate complex template class */
#endif
Is this right? I believe it should be (regarding 'include/petscmath.h')
template <> class std::complex<PetscReal>;
or perhaps better:
#if defined(PETSC_USE_SINGLE)
template <> class std::complex<float>;
#elif defined(PETSC_USE_LONG_DOUBLE)
template <> class std::complex<long double>;
#elif defined(PETSC_USE_INT)
template <> class std::complex<int>;
#else
#endif
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
