MPIDense row distribution on transpose.
    Alex Peyser
    a.peyser at umiami.edu
    Thu Sep  4 22:06:36 CDT 2008
All,
In petsc-2.3.3_p11, when I do a transpose on an MPIAIJ, the MatTranspose
conserves the row distribution pattern of the parent, so a 5x5 matrix
transposed can still be multiplied by a 5-vector that the parent could be
multiplied by (0-1,2-4 for everyone). However, with an MPIDENSE, I get a row
rearrangement so that mpi process 1,2 now have (0-2, 3-4), which leads to
nonconforming object size errors.
Is this a known bug in MPIDense ? Is there a workaround - some way to force
the matrix arrangement on tranpose for an MPIDense?
I see that in MatTranspose_MPIAIJ, MatSetSizes is called
with (A->cmap.n, A->rmap.n, N, M), which conserves my layout,
while in MatTranspose_MPIDense, MatSetSizes is called
with (PETSC_DECIDE, PETSC_DECIDE, N, M), which then ruins my layout. The
former would appear to me the correct sequence.
Alex Peyser
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080904/ba860541/attachment.sig>
