possible new problem: dynlibs retrieved twice, need advice for fix
Lisandro Dalcin
dalcinl at gmail.com
Tue Oct 21 10:04:15 CDT 2008
Barry, I catched a new problem. At PetscInitialize(), dynamic
libraries are 'retrieved' twice. The calls that leads to this are the
following:
PetscInitialize()
PetscInitialize_DynamicLibraries()
PetscLoadDynamicLibrary() // helper routine for opening each libpescXXX lib
PetscDLLibraryRetrieve() // FIRST call
PetscDLLibraryAppend()
PetscDLLibraryOpen()
PetscDLLibraryRetrieve() // SECOND call
However, I'm not sure if this is a real issue. It seems that
./bin/urlget.py is smart enough as to skip downloading based on
timestamps (though I'm not sure if the same applies to the wget
fallback in 'bin/urlget' shell script)
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
