new thoughts on dynamic libraries support
Barry Smith
bsmith at mcs.anl.gov
Mon Oct 20 16:34:36 CDT 2008
On Oct 20, 2008, at 1:49 PM, Lisandro Dalcin wrote:
> PetscDLLibraryRegister_NAME. If the symbol is not exported, then
> PetscDLLibraryOpen() fails!! BTW, Because of this constraint,
> PFSTRING implementation is currently broken.
I don't understand why this would be. The PF stuff is in the Vec
library.
PetscErrorCode PETSCVEC_DLLEXPORT
PetscDLLibraryRegister_petscvec(const char path[])
PetscErrorCode ierr;
ierr = PetscInitializeNoArguments(); if (ierr) return 1;
PetscFunctionBegin;
If we got here then PETSc was properly loaded
ierr = ISInitializePackage(path);CHKERRQ(ierr);
ierr = VecInitializePackage(path);CHKERRQ(ierr);
ierr = PFInitializePackage(path);CHKERRQ(ierr);
PetscFunctionReturn(0);
The PF is suppose to work in the same way as the IS, I'm guessing the
IS works properly?
Thanks
Barry
