Reporting cpu times to profile KSPSolve (and others)
Dave May
dave.mayhem23 at gmail.com
Fri May 9 01:09:13 CDT 2008
Hey Matt,
All I want to be able to do is generate plots of |r|/|r0| vs cpu time. I
presumed that such information is commonly required when profiling the
performance of solvers, so I thought it might be something you'd consider
adding support for.
Cheers,
Dave
On Fri, May 9, 2008 at 1:19 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 8, 2008 at 10:09 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> > Hey petsc folk,
> > What is the best way to obtain timing information to profile the
> > performance
> > of KSPSolve (or SNESSolve)? Currently I have written some specific KSP
> > monitors,
> > but it I think it would be useful to have access to this information all
> the
> > time without
> > having to go through the monitor. It seems like each object should know
> how
> > to time
> > some of its operations.
> > It would be very useful to have functions such as
> > KSPGetCPUTime(KSP ksp,PetscLogDouble *time)
> > to report the total solution time required by the KSPSolve() and
> > KSPGetCPUTimeHistory(KSP ksp,PetscLogDouble *time[],PetscInt *na)
> > which is like KSPGetResidualHistory() but returns the accumulated cpu
> time
> > for each
> > iterate
> > It would also be useful to have a default KSP monitor which could report
> the
> > time per iterate
> > or accumulate time. For example something like
> > 40 KSP Residual norm 1.519638506430e-01 Time 1.000000000000e-03
> > 41 KSP Residual norm 1.510346481853e-01 Time 1.510346481853e-02
> > Is there a better approach to what I've been doing and are there plans to
> > add any
> > additional features to help profile individual operations on each object?
> Maybe you could motivate it by giving a use case? So far, I have never
> needed
> anything but the KSPSolve() event and stages to separately aggregate
> different
> types of solves.
> Matt
> > Cheers,
> > Dave
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080509/9389149b/attachment.html>
