ML with OpenMPI
Tue Mar 25 06:17:10 CDT 2008
    I have pushed this fix to petsc-dev
    Thank you for figuring this out,
    Barry
On Mar 25, 2008, at 2:38 AM, Jed Brown wrote:
> On Sat 2008-03-22 10:19, Lisandro Dalcin wrote:
>> Give a try. When using MPICH2, PETSc just passes
>> "--with-mpi=PATH_TO_MPI" and ML get it right. Perhaps ML have some
>> trouble with OpenMPI, I've never tried. If you built OpenMPI yourself
>> and with shared libs, do not forget to define LD_LIBRARY_PATH to
>> point
>> to the dir with the OpenMPI libs. If not, some configure test of ML
>> could fail, and then MPI is assumed to be absent.
> It turns out I was chasing this in entirely the wrong direction.  ML
> was
> configured just fine and was correctly using MPI, but we had not
> defined
> HAVE_CONFIG_H so ml_common.h was not setting all the variables that
> depend on
> ml_config.h.  In particular, ml_config.h sets HAVE_MPI correctly,
> but the
> following is in ml_config.h:
> #ifdef HAVE_CONFIG_H
> #ifdef HAVE_MPI
> #ifndef ML_MPI
> #define ML_MPI
> #endif
> #endif
> #endif /*ifdef HAVE_CONFIG_H*/
> Indeed, adding -DHAVE_CONFIG_H to CFLAGS in src/ksp/pc/impls/ml/
> makefile fixes
> the problem (and the manual include of ml_config.h in ml.c becomes
> unnecessary).
> That is, the patch below makes everything work correctly.
> Jed
> diff -r 2ae11e456aa7 src/ksp/pc/impls/ml/makefile
> --- a/src/ksp/pc/impls/ml/makefile      Fri Mar 21 17:33:24 2008 -0500
> +++ b/src/ksp/pc/impls/ml/makefile      Tue Mar 25 08:35:12 2008 +0100
> @@ -5,7 +5,7 @@
> ALL: lib
> -CFLAGS   = ${ML_INCLUDE}
> +CFLAGS   = ${ML_INCLUDE} -DHAVE_CONFIG_H
> FFLAGS   =
> SOURCEC  = ml.c
> SOURCEF  =
> diff -r 2ae11e456aa7 src/ksp/pc/impls/ml/ml.c
> --- a/src/ksp/pc/impls/ml/ml.c  Fri Mar 21 17:33:24 2008 -0500
> +++ b/src/ksp/pc/impls/ml/ml.c  Tue Mar 25 08:35:12 2008 +0100
> @@ -10,7 +10,6 @@
> #include <math.h>
> EXTERN_C_BEGIN
> -#include "ml_config.h"
> #include "ml_include.h"
> EXTERN_C_END
