petscvariables: hardwired build dir instead of install dir
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Mar 24 21:50:01 CDT 2008
On Mar 24, 2008, at 10:57 AM, Lisandro Dalcin wrote:
> Barry, things are still broken. I think that at some point we have to
> review the 'install:' target  more carefully.
> First, the 'sed' command i being called in a wrong way.
    This is not true; the sed is being called correctly. The problem
is that -i
is not a standard sed option and different systems gnu and freebsd treat
it differently. freebsd requires a space between the -i and the suffix;
gnu has no space; gnu also allows the use of -i to indicate no backup
while freebsd expects -i ""
   Your patch works on POS gnu systems, but is broken on far superior
Apple MacOS X systems! :-)
    Matt you need to add a config/configure.py test to detect the
type of sed -i it is.
> Second, ALL files under $PETSC_ARCH/conf are being copied, I'm not
> sure if all them are needed (logs, RDict.db, configure.py, etc) when
> you 'install' PETSc in a central, system location.
   I like copying everything because they tell exactly what build was
done
with what options. But if it is being dumped into a generic conf
directory
yes it will be confusing, but then the files rules, variables and base
are confusing because they are not marked as PETSc related
> Finally, 'sed' trickery is done under all files under 'conf/' and that
> can be dangerous.
   Yes, if it is a generic conf directory it is kind of a problem.
    Barry
> I attach a hg diff fixing some of that issues. But I still believe
> that this have to be more carefully reviewed. Unfortunately, I will
> not be able to do that myself for, let say, three month from now.
> By using the patch in the attached file, I was able to install PETSc
> and next build petsc4py. However, this does not necesarily means that
> things are all OK. I already do some trickery in the build system of
> petsc4py in order to 'fix' the problems with the stuff in PETSc
> makefiles since version 2.3.2 until latest petsc-dev.
> Regards,
> On 3/22/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Lisandro
>>    The rule was a total mess; I think I have fixed it now, please try
>> again
>> and let me know how it goes.
>>   Thanks for reporting the problem,
>>    Barry
>> On Mar 22, 2008, at 1:18 PM, Lisandro Dalcin wrote:
>>> OK, it seems my stderr were being sent I do not know were... I get
>>> the
>>> following (BTW, I was not aware of the 'sed' trick, but I was not
>>> seeing the error)
>>> [root at trantor petsc-dev]# make install
>>> Installing PETSc at /usr/local/petsc/dev/linux-gnu
>>> sed: can't read s?${PETSC_DIR}?TMP_INSTALL_DIR?g: No such file or
>>> directory
>>> sed: can't read s?TMP_INSTALL_DIR?/usr/local/petsc/dev/linux-gnu?
>>> g: No
>>> such file or directory
>>> sed: can't read s?/${PETSC_ARCH}??g: No such file or directory
>>> making shared libraries in /usr/local/petsc/dev/linux-gnu//lib
>>> building libpetsc.so
>>> building libpetscvec.so
>>> building libpetscmat.so
>>> building libpetscdm.so
>>> building libpetscksp.so
>>> building libpetscsnes.so
>>> building libpetscts.so
>>> building libpetsccontrib.so
>>> sh/bash: PETSC_DIR=/usr/local/petsc/dev/linux-gnu; export PETSC_DIR
>>> sh/bash: unset PETSC_ARCH
>>> csh/tcsh: setenv PETSC_DIR  /usr/local/petsc/dev/linux-gnu
>>> csh/tcsh: unsetenv PETSC_ARCH
>>> Then do make test to verify correct install
>>> And then the 'petscvariables' still have the build dir in many
>>> places.
>>> So the 'sed' command is not working for me. I do not know way, I've
>>> never had the time to learn regexps :-(.
>>> BTW, I'm on a Fedora 6 box.
>>>>  Ok, I think I understand your concern,
>>>>>>    Do you mean that it lists, for example,
>>>>>> SUPERLU_DIST_LIB = -Wl,-rpath,/Users/bsmith/Src/petsc-dev/arch-
>>>>>> icc-
>>>>>> superlu_dist/lib -L/Users/bsmith/Src/petsc-dev/arch-icc-
>>>>>> superlu_dist/
>>>>>> lib -lsuperlu_dist_2.2
>>>>>> instead of
>>>>>> SUPERLU_DIST_LIB = -Wl,-rpath,$PETSC_DIR/arch-icc-superlu_dist/
>>>>>> lib -L
>>>>>> $PETSC_DIR/arch-icc-superlu_dist/lib -lsuperlu_dist_2.2
>>>>> exactly that, as an example, I've just built petsc-dev, passing as
>>>>> prefix the following '--prefix=/usr/local/petsc/2.3.3/linux-
>>>>> gnu' (yes,
>>>>> I still want to have multiconfig installations of petsc in a
>>>>> central
>>>>> location, so I add the PETSC_ARCH to the prefix)
>>>>> But the 'petscvariables' file stills says, for example
>>>>> ML_INCLUDE = -I. -I/usr/local/mpich2/1.0.6/include
>>>>> -I/repos/hg/petsc/petsc-dev/linux-gnu/include
>>>>   This is because the place we want ML to install itself has be
>>>> passed in as the true path, it cannot be sent as a symbolic
>>>> PETSC_DIR
>>>> since configure of the subpackage doesn't know PETSC_DIR
>>>>> The last include dir is the directory were I've built PETSc. I
>>>>> would
>>>>> love to see that include as -I${PETSC_DIR}/${PETSC_ARCH}/include.
>>>>> And
>>>>> now, if external packages got installed in $PETSC_DIR/$PETSC_ARCH,
>>>>> we
>>>>> perhaps could just put nothing, as that location is always taken
>>>>> into
>>>>> accout for PETSc itself.
>>>>> The real problem: if I remove the build dir, the 'petscvariables'
>>>>> point to locations that no longer exists, This is dangerous. I
>>>>> already
>>>>> had trouble in the past with the old 'bmake' based system. Is
>>>>> there a
>>>>> chance to 'fix' this, or I'm missing something?
>>>>  make intall: see the rule in makefile is suppose to replace all
>>>> uses of the
>>>> petsc-dir directory with the final prefix installed location: the
>>>> lines
>>>>          sed -i "" 's?$${PETSC_DIR}?TMP_INSTALL_DIR?g' $
>>>> {INSTALL_DIR}/conf/* ;\
>>>>          sed -i "" s?TMP_INSTALL_DIR?${INSTALL_DIR}?g $
>>>> {INSTALL_DIR}/
>>>> conf/* ;\
>>>> would replace
>>>> /usr/local/petsc/2.3.3/linux-gnu/include
>>>> Now it could be that the sed is not working when you run install?
>>>> Can
>>>> you do a
>>>> config/configure.py with a --prefix then the make then the make
>>>> install and see what
>>>> goes wrong?
>>>>  Barry
>>>> with
>>>>> Lisandro Dalcín
>>>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>>>> (CIMEC)
>>>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>>>> (INTEC)
>>>>> Consejo Nacional de Investigaciones Científicas y Técnicas
>>>>> (CONICET)
>>>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>>>> Tel/Fax: +54-(0)342-451.1594
>>> Lisandro Dalcín
>>> (CIMEC)
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> <make_install.diff>
