petscvariables: hardwired build dir instead of install dir
    Matthew Knepley
    knepley at gmail.com
    Mon Mar 24 11:04:24 CDT 2008
If someone explains to me in words what that sed crap is doing, I will
rewrite it in python.
     Matt
On Mon, Mar 24, 2008 at 10:57 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Barry, things are still broken. I think that at some point we have to
>  review the 'install:' target  more carefully.
>  First, the 'sed' command i being called in a wrong way.
>  Second, ALL files under $PETSC_ARCH/conf are being copied, I'm not
>  sure if all them are needed (logs, RDict.db, configure.py, etc) when
>  you 'install' PETSc in a central, system location.
>  Finally, 'sed' trickery is done under all files under 'conf/' and that
>  can be dangerous.
>  I attach a hg diff fixing some of that issues. But I still believe
>  that this have to be more carefully reviewed. Unfortunately, I will
>  not be able to do that myself for, let say, three month from now.
>  By using the patch in the attached file, I was able to install PETSc
>  and next build petsc4py. However, this does not necesarily means that
>  things are all OK. I already do some trickery in the build system of
>  petsc4py in order to 'fix' the problems with the stuff in PETSc
>  makefiles since version 2.3.2 until latest petsc-dev.
>  Regards,
>  On 3/22/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  > Lisandro
>  >     The rule was a total mess; I think I have fixed it now, please try
>  >  again
>  >  and let me know how it goes.
>  >    Thanks for reporting the problem,
>  >     Barry
>  >  On Mar 22, 2008, at 1:18 PM, Lisandro Dalcin wrote:
>  >  > OK, it seems my stderr were being sent I do not know were... I get the
>  >  > following (BTW, I was not aware of the 'sed' trick, but I was not
>  >  > seeing the error)
>  >  > [root at trantor petsc-dev]# make install
>  >  > Installing PETSc at /usr/local/petsc/dev/linux-gnu
>  >  > sed: can't read s?${PETSC_DIR}?TMP_INSTALL_DIR?g: No such file or
>  >  > directory
>  >  > sed: can't read s?TMP_INSTALL_DIR?/usr/local/petsc/dev/linux-gnu?g: No
>  >  > such file or directory
>  >  > sed: can't read s?/${PETSC_ARCH}??g: No such file or directory
>  >  > making shared libraries in /usr/local/petsc/dev/linux-gnu//lib
>  >  > building libpetsc.so
>  >  > building libpetscvec.so
>  >  > building libpetscmat.so
>  >  > building libpetscdm.so
>  >  > building libpetscksp.so
>  >  > building libpetscsnes.so
>  >  > building libpetscts.so
>  >  > building libpetsccontrib.so
>  >  > sh/bash: PETSC_DIR=/usr/local/petsc/dev/linux-gnu; export PETSC_DIR
>  >  > sh/bash: unset PETSC_ARCH
>  >  > csh/tcsh: setenv PETSC_DIR  /usr/local/petsc/dev/linux-gnu
>  >  > csh/tcsh: unsetenv PETSC_ARCH
>  >  > Then do make test to verify correct install
>  >  > And then the 'petscvariables' still have the build dir in many places.
>  >  > So the 'sed' command is not working for me. I do not know way, I've
>  >  > never had the time to learn regexps :-(.
>  >  > BTW, I'm on a Fedora 6 box.
>  >  >>   Ok, I think I understand your concern,
>  >  >>>>     Do you mean that it lists, for example,
>  >  >>>> SUPERLU_DIST_LIB = -Wl,-rpath,/Users/bsmith/Src/petsc-dev/arch-icc-
>  >  >>>> superlu_dist/lib -L/Users/bsmith/Src/petsc-dev/arch-icc-
>  >  >>>> superlu_dist/
>  >  >>>> lib -lsuperlu_dist_2.2
>  >  >>>> instead of
>  >  >>>> SUPERLU_DIST_LIB = -Wl,-rpath,$PETSC_DIR/arch-icc-superlu_dist/
>  >  >>>> lib -L
>  >  >>>> $PETSC_DIR/arch-icc-superlu_dist/lib -lsuperlu_dist_2.2
>  >  >>> exactly that, as an example, I've just built petsc-dev, passing as
>  >  >>> prefix the following '--prefix=/usr/local/petsc/2.3.3/linux-
>  >  >>> gnu' (yes,
>  >  >>> I still want to have multiconfig installations of petsc in a central
>  >  >>> location, so I add the PETSC_ARCH to the prefix)
>  >  >>> But the 'petscvariables' file stills says, for example
>  >  >>> ML_INCLUDE = -I. -I/usr/local/mpich2/1.0.6/include
>  >  >>> -I/repos/hg/petsc/petsc-dev/linux-gnu/include
>  >  >>    This is because the place we want ML to install itself has be
>  >  >> passed in as the true path, it cannot be sent as a symbolic PETSC_DIR
>  >  >> since configure of the subpackage doesn't know PETSC_DIR
>  >  >>> The last include dir is the directory were I've built PETSc. I would
>  >  >>> love to see that include as -I${PETSC_DIR}/${PETSC_ARCH}/include.
>  >  >>> And
>  >  >>> now, if external packages got installed in $PETSC_DIR/$PETSC_ARCH,
>  >  >>> we
>  >  >>> perhaps could just put nothing, as that location is always taken
>  >  >>> into
>  >  >>> accout for PETSc itself.
>  >  >>> The real problem: if I remove the build dir, the 'petscvariables'
>  >  >>> point to locations that no longer exists, This is dangerous. I
>  >  >>> already
>  >  >>> had trouble in the past with the old 'bmake' based system. Is
>  >  >>> there a
>  >  >>> chance to 'fix' this, or I'm missing something?
>  >  >>   make intall: see the rule in makefile is suppose to replace all
>  >  >> uses of the
>  >  >> petsc-dir directory with the final prefix installed location: the
>  >  >> lines
>  >  >>           sed -i "" 's?$${PETSC_DIR}?TMP_INSTALL_DIR?g' $
>  >  >> {INSTALL_DIR}/conf/* ;\
>  >  >>           sed -i "" s?TMP_INSTALL_DIR?${INSTALL_DIR}?g $
>  >  >> {INSTALL_DIR}/
>  >  >> conf/* ;\
>  >  >> would replace
>  >  >> /usr/local/petsc/2.3.3/linux-gnu/include
>  >  >> Now it could be that the sed is not working when you run install? Can
>  >  >> you do a
>  >  >> config/configure.py with a --prefix then the make then the make
>  >  >> install and see what
>  >  >> goes wrong?
>  >  >>   Barry
>  >  >> with
>  >  >>> Lisandro Dalcín
>  >  >>> Centro Internacional de Métodos Computacionales en Ingeniería
>  >  >>> (CIMEC)
>  >  >>> Instituto de Desarrollo Tecnológico para la Industria Química
>  >  >>> (INTEC)
>  >  >>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>  >  >>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>  >  >>> Tel/Fax: +54-(0)342-451.1594
>  >  > Lisandro Dalcín
>  >  > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>  >  > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>  Lisandro Dalcín
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
