ML with OpenMPI
Barry Smith
bsmith at mcs.anl.gov
Fri Mar 21 17:14:37 CDT 2008
Jed,
You can take a look at config/PETSc/packages/ml.py; essentially we
call their configure with a given set of compilers (and MPI
information).
So I would say you have to report the bug to those folks; their
configure
should handle that issue, shouldn't it.
Barry
On Mar 21, 2008, at 5:09 PM, Jed Brown wrote:
> The MPI standard does not specify that MPI_Comm = int and in fact
> OpenMPI uses a pointer value which lets the compiler do slightly more
> type checking. This type checking recently caused me trouble when
> building with-download-ml.
> There is a line in ml_comm.h which defines their communicator to be an
> int when ML_MPI is not defined. It was not immediately clear why this
> is not defined, but result is that the compiler chokes when building
> PETSc. This patch fixes the problem as long as sizeof(int) =
> sizeof(MPI_Comm), but this is *not* the case on x86_64 with OpenMPI.
> It's not clear to me how much of this is an upstream issue and how
> much
> is a configuration issue.
> Jed
> diff -r c074838b79ed src/ksp/pc/impls/ml/ml.c
> --- a/src/ksp/pc/impls/ml/ml.c Thu Mar 20 17:04:05 2008 -0500
> +++ b/src/ksp/pc/impls/ml/ml.c Fri Mar 21 22:50:32 2008 +0100
> @@ -815,7 +815,7 @@ PetscErrorCode MatWrapML_SHELL(ML_Operat
> MLcomm = mlmat->comm;
> ierr = PetscNew(Mat_MLShell,&shellctx);CHKERRQ(ierr);
> - ierr =
> MatCreateShell(MLcomm-
> USR_comm
> ,m,n,PETSC_DETERMINE,PETSC_DETERMINE,shellctx,newmat);CHKERRQ(ierr);
> + ierr =
> MatCreateShell((MPI_Comm)MLcomm-
> USR_comm
> ierr =
> MatShellSetOperation(*newmat,MATOP_MULT,(void(*)
> (void))MatMult_ML);CHKERRQ(ierr);
> ierr =
> MatShellSetOperation(*newmat,MATOP_MULT_ADD,(void(*)
> (void))MatMultAdd_ML);CHKERRQ(ierr);
> shellctx->A = *newmat;
> @@ -844,7 +844,7 @@ PetscErrorCode MatWrapML_MPIAIJ(ML_Opera
> n = mlmat->invec_leng;
> if (m != n) SETERRQ2(PETSC_ERR_ARG_OUTOFRANGE,"m %d must equal to n
> %d",m,n);
> - ierr = MatCreate(mlmat->comm->USR_comm,&A);CHKERRQ(ierr);
> + ierr = MatCreate((MPI_Comm)mlmat->comm->USR_comm,&A);CHKERRQ(ierr);
> ierr = MatSetSizes(A,m,n,PETSC_DECIDE,PETSC_DECIDE);CHKERRQ(ierr);
> ierr = MatSetType(A,MATMPIAIJ);CHKERRQ(ierr);
> ierr =
> PetscMalloc3
> (m,PetscInt,&nnzA,m,PetscInt,&nnzB,m,PetscInt,&nnz);CHKERRQ(ierr);
